Skyfrog
Brandon, FL
Back to the mods
It's been a while since I've done any mods to my 2014 SCREW. That sort of thing happens when low on cash, (out of work on Long Term Disability due to back injury).
Anyway, my KO's were riding very rough, scalloped, and were beginning to hydroplane in rain. They only had 54K miles on them, but I guess that's not bad from what have I read.
I decided on the 37 KO2s and there were a lot of Black Friday deals going on. But after reading all the threads on mid-perch, pinch-weld (didn't find a good step-by step guide), bump stops, and Fox 3.0 as probable prerequisites, I figured I will do those on the next set, when the warranty expires. So instead I went with the 35 KO2 E rated and in stock. Amazing difference with the new tires, very quiet and smooth.
Also, I had intended to go with the "blacked out" look, but decided instead to add more "colorful mods" in the future. Therefore I went with the white lettering out. This is my first time on any car or truck with the white letters out, but I think they look pretty good.
I will start adding more mods as money allows. Any suggestions on what mod I should do next are welcome. Hmmm, perhaps a lift kit I spotted at the tire place :ROFLJest:
2014RubyRed
Galesburg, IL
I would go with 3.0's next. That will help with any mod you have next. Do you have stock rear leafs still? Upgrade those. That was probably the single best mod I have ever done. Really improved the ride quality!!!
Skyfrog
Brandon, FL
I would go with 3.0's next. That will help with any mod you have next. Do you have stock rear leafs still? That was probably the single best mod I have ever done. Really improved the ride quality!!!
Thanks, that's what I was thinking too. I've read more than one owner who needed to rebuild the stock shocks before 50K miles, so I'll keep them high on my mod priority list.
I haven't researched the rear leafs springs yet. Which make/model did you get?
2014RubyRed
Galesburg, IL
Currently have Deaver +3's, but they are starting to sag. Going with WSI HD's next as they seem to be holding their arch much better.
If you are mainly street use, Deaver +2 or WSI SD would be good for you. It really takes away that wondering rear-end feeling you get on the off ramps at high speeds.....
cobrajet
Wisconsin
Love the white letter out!
Ramathorn178
Selah, WA
Redid glove box aux connections 1-4
Fixed 42" radius front bumper light
Made brackets and installed 42" straight bar behind grill
Cut three trees down in our garden
Wired up canopy dome and brake lights
Didn't get a chance to wire up the rear bumper lights but, hopefully in the morning I'll get a chance to knock those little ******* out.
Raven13
College Station, TX
Another vote for rear spring upgrade. I have Deaver +3's and difference is substantial.
Wilson
South Dakota
your good way to have a link
washed mine I still need to start over starting to get build up.
ih6aYEkeJUm5TnvkaVkXRn3Iuy25E4xkjOlVB8sS6KfsLlXksM1lPdpVUCQyRZrPfOds2q6jyt69zzRwBZWQsvPbbqKFT1Ix-okUiiZVr_ZeeREqsj0gb4YcEix59JrnqdD8n2TsFDeQ88unse95iX6MrvxdgiebZD3k0sO-OiC_PRCDSrL-_owNJmf7DIFrQp3QW9wvUMsC_s-VVoZHr0FwJoWSJYSiJ-q2CzLUyI-cimVS1LJ4RzqR_5-mm5mBCFRVZP9uQX_qGLq-cG6uJ0yUYmmWvBnBK0oyou0ZmRp55fGmkg_cSyxyQsbmPuPmlW2aCz4BS8_waKqrWClM_WbTYWqiHA4QqKXF_11SnfiFv7MBuq-uduIiOo_YxGJYEPZ2T9H2eip8Os0G6xT91c6CfPoxejkPJ6_jRciIjlP11PcrKAZMrS_NtrnkbPLf_SxcIcTXDn-yJKcLzRCf4WjPIF54a2IvxNTR9eK7-NLl1iA5YPrjxD7iMrTjuTKztlLEi-wDqyq9vEe7_s8Ri5dfBTNSHI6hcQS9mK3-3roViiGXDwQll_q9MzjsSzjHIrIiI6fti6NVZp-IBvS1SL6tt8CRg6uuKVtdiOIhaCFz3Lr36g=w1024-h576-no
