The ultimate power steering set up?
AndysLog
Moro IL
i personally believe the pulley on the pump just needs be larger.
that would clear up all issues except for the pump cracking maybe. well if less pressure and heat would help it not break ha.
Deleted member 12951
Not arguing, but what makes you think those 2 components cause issues? I can see the flow reducer being an issue, but why the factory cooler?
The stock PS cooler tubing runs through the same part of the radiator and because of that is not efficient on cooling the fluid, actually can create heat hence why he removed it completely and bypassed it as I understand it.
Hole Shot
Raeford, Nc.
Fixing my truck and numerous others that have had numerous failures back to back. I believe that the stock cooler holds lots of trash from blown pumps and also air that will not bleed and causes more failures with compounding issues until removed from the system.
stewwalker
stewwalker
Kingsville/Houston
Haven't took an in-depth look at the stock cooler. Just figured it was a heat exchanger and the fluid was piped through the top of the the radiator.
Raptor1988
Phoenix Az
Few months old thread but I like the ideas. I am going to tackle this next month. I have had 2 pumps go out on me in the course of 2 months and 3 offroading trips.
On my list will be an RPG PS resevoir
Derale cooler and 10 inch fan
Aluminum magnefine power steering filter
I will also be bypassing the condensor cooling for the ps.
@SZDZMTR hows your setup been holding up? Any offroad or dune action?
SZDZMTR
Sewell, NJ
No issues so far. I am in NJ so far just one trip to Wharton State park and just regular daily driving. About 15k miles since the install...I wish they had dunes here. lol And I don't frequent Starbucks either. Had to give it to Ford after changing the PS fluid locally still had air in the system and it was whining like pig until the mechanic at Ford got rid of all the air bubbles. Now nice and silent.
Sozzy12
South Idaho
Anyone know if the super duty pump, reservoir, etc. Are the same pieces, and if not, will they bolt on a Rappy? Was just wondering. I'd think the super duty stuff might be tougher.
