Turn signal noise is actually a speaker?
swoop1156
USA
So, I ran across this Easter egg the other day when I was doing something or another in the truck. I've come to the realization that the Raptor does not like to multi-task. It doesn't want to do a Bluetooth/SYNC phone call, run NAV, tell me directions to turn and then emit the sound for the turn signal. It was something like that anyway...
I think I was just hanging up the call, the bitch was trying to talk (the NAV, not the one on the phone), I was turning on the turn signal.
The turn signal was on, flashing on and off on my dash -- but there was no annoying sound. As soon as it was on for a few seconds and something stopped -- either the call, which wouldn't make sense because I've heard the signals noise before during a call and then the NAV talking to me (which I never have on, but I was on a road trip and no idea where I was going in Atlanta)...but the signal tick tock tick tock was not happening.
I would like it if I could disable that annoying Jack Russel of a ******* noise permanently.
Anyone?
lacrosseman812
u should be able to turn the voice off cause i know that u can in most gps systems all three of my families cars has a nav system and all can turn the voice off and they are 3 different car brands go to like the menu on nav
Maxx2893
Rock and Roll Offroad
Burleson, TX
I think he meant the turn signal
BIRDMAN
Birdministrator
Boston
get a big enough hammer and you can make anything stop making noise...
JP7
Likes Canadian Mudbaths
Calgary, Alberta
Ima find that speaker and rip it out - I'm on the phone constantly while driving and them turn signals sure are a converstion stopper. When I find it, I'll post up a pick of what I destroy.
Droid
kglesq's Brother
Everything is playing through the radio speakers. This is a computer/programming issue, there are a given number of audio channels available/allowed, and once those are exceeded the computer either stops playing new sounds or prioritizes them appropriately.
My 2004 GMC Sierra had the same type of feature.
It'd be great to hack the BCM and add a less lame turn signal track. Of course if that was possible I'd then have to secretly change kglesq's to someone saying "you are turning left/right" once a second.
swoop1156
swoop1156
USA
That would be awesome...
You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left... You are turning left...
FFFFFFUUUUUUCCCCCCKKKKKK!
That's ONE left turn!
jdowens1
Ford Senior Master Technician
Montana
You are right the warning chimes are prioitized, but i don't think it plays through ACM (audio control module) all warning chimes are inputs sent to IPC (instrument panel) via network from other modules. I did look over wiring I think sounds play out of IPCbut I'm not 100%, if you do disable it will disable all warnings including hill decent chime SRS fault chime TCS fault chime basically all warning and fault chimes will be disabled.
OneArmedViolinist
Denver
Dont tell me your one of those morons that sits at a traffic light for 2 minutes with their blnker going the whole time. I only turn it on when the light turns green..... that way I dont burn out my bulbs..... LOL Im a phucken genious..... bwhahaha
