HAYNES OFFROAD
aka Wreckless
Paddles are great for sand. They act like balloons and keep the tires on top of the sand, and give you great traction taking off and lower speeds. But once your up to speed, they produce a lot of drag and you do need a lot of power to turn them over and keep accelerating. Paddles on a stock powered raptor would prolly not do that great. They would work from a stop and low speed, but your high speed stuff is gonna be affected. Also will make the rear a bit loose at higher speeds as wel unless you get a set that has inline paddles to help with side to side stability.
