Trailer disconnected in dash.
Hoverp
Central Montana
So I bought a trailer that was wired for a f150, and uses the 7 round light plug. It has electric brakes and every thing works great other than the truck doesn't know the trailer is connected when it's plugged in. I get the " trailer disconnected " warning in the dash when I apply the trailer brake on the dash.
All any idea ? What contact in the 7 round tells the truck that the trailer is there?
Thanks!
Hoverp
Hoverp
Central Montana
This trailer has electric brakes , no battery, so the charging fuse would not need to be installed, I was wondering what pin on the 7 tells the truck the trailer is connected?
When I use the manual brake on the TBC it displayed the warning and the trailer brakes don't work..
I'll double check all wires.
Hoverp
Hoverp
Central Montana
No sir I didnt, from reading here and elsewhere that the fuse and relay was only there to charge the trailer breakaway battery , which mine does not have. Is it required to have those in to make the connection so the truck knows the trailer is back there?
Hoverp
Hoverp
Central Montana
Ok I'll put them in, I just went out to the truck and got them out of the glove box. " Hey there made in USA"
What fuse slots do they go into ?
