Got tired of TPMS SENSOR FAULT, 2-SENSORS FAILED less then 2 yrs, so I did a little research and found this little item, TPMS BYPASS.
This little box can be used with TPMS sensors installed or not installed at all, it tricks the trucks computer into thinking all 4 sensors are working correctly, no more WARNING, FAULT LIGHT BLINKING.
This little box measures 2 1/2 x 2 1/2 x 3/4, and takes 2-AA batteries,
all you need to do is follow the instructions as if your programming new sensors. Thought this would be of interest to you guys that air down your tire a lot and not trigger your TPMS LIGHT.
Item was purchased from tpmsbypass.com , using there ebay.com/srsdrive-store.
