Towing a Gooseneck Trailer?
Humvee21
You're gonna want to open the moon roof and hook up the fifth wheel there. It will help distribute the weight much better and your MPG won't be as bad.
Aaron
Aaron
Meme Corps Commandant
WA
Interesting concept. I wonder if I could weld onto an ADD chase rack and do it that way?
mcote1
Way down yunder
Which one would you recommend?
I want to do this the right way.
Well, if you want to go with something cheap and quick that will last a while, I would recommend using pressure treated 2x4's. You will just have to drill holes in the appropriate places
Aaron
Aaron
WA
My neighbor lifted his old 73 chevy that way. Seemed ok but I think I'll go with a 2" daystar.
Ditchplains1
Trescott, ME
Aaron,
I used 6 hockey pucks stacked on one another at each body mount, but it wasn't enough so I stacked on 3 more. I used a wood drill bit to drill the bolt hole through the pucks. Bolts were too short so I scored some 30" zip ties and used 4 at each mount.
Nice cushy ride, but there is some body roll....
Eddie
