How can I put a winch in my stock front bumper like the raptor in this video. Is there a kit? Is the bumper designed for a winch to be mounted here already?
BigBadChad,
I've put winches on two of my trucks in the past. Most winches come with quick connect electrical connectors. That's the only wiring needed. You could put in a 440 amp fuse, (12,000# Warn winch draws 440 amps at 12,000# pull on outer layer of drum), but otherwise connect the leads to the battery. Most winches have remotes...either wired that plug into the winch, or wireless remote.
I have not installed a winch in my Gen 1...yet; but many have and it requires mostly bolt on brackets with modifying/removing the lower grille. Take your time, and it should be a 1-2 wrench job in terms of difficulty.
Goforit!
https://www.awdirect.com/connector-harness-4-superior-signals-stc918k-4/jump-start-sets/
Eddie
