Squeaking from bed?
S197Mach1
Chesapeake, VA
So I'm noticing I have some squeaking when the bed bounces while going over bumps in the road. What do you think is the culprit and is it something I could easily lubricate or tighten?
Mick VT
tailgate seems to get a lot of squeak complaints, good place to start
S197Mach1
S197Mach1
Chesapeake, VA
Figured it out. A little lithium grease on the pegs where the tailgate grasps when it is up solved the squeaks.
AZEngineer
Phoenix AZ Area
Mine ended up being a loose bolt that mounts the passenger rear spring to the front spring mount. Took forever. There is also a cast iron damper on top of the drivers side rear frame near the tailgate. Some have reported that the rubber mounts deteriorated and the damper squeaked.
