Spare tire key plug
TheJoker
N. E. Massachusetts
you will need a new pin set. i have rekeyed a few locks and usually they come with a new pin tumbler set. they are small metal rods of different lengths and theres a good possibility that the pins in another persons lock are not the same lengths so you cant reuse them. sometimes the pins line up if they are moved to a different spot, but to get all of them to match is not likely
Correct, but, a good locksmith should be able to scrounge up something.
I've rekeyed my storm door to use the same key as my other doors in my house, and that was easy.
DCSVT1
Medford NJ
I just lost mine this past weekend, however I don't believe it was a key plug, but just a flip open butt-plug. I didn't even drop the spare, just noticed the empty hole today. Anybody else have a flip open cap/hole? Sounds much better than the $150 cheesey key lock one. If so, part number??
pat247
pat247
Oklahoma
I just realized that I never updated this thread. When this first happened I thought, no big deal right, maybe $20-$30 mistake. Wrong!!! This started in April 2015 and ended in February 2016 when the local dealership rekeyed the lock cylinder for me. I bought the lock cylinder kit (4L3Z-1543262-BC) in June 2015 thinking that I would be able to do this myself. Took one quick look at the instructions, then procrastinated until February 2016.
Total cost of this little mishap ended up being right at $200+. Lesson learned...........until next time. Ha Ha
