twlhunter65
Well-Known Member
I cant find a thread on how to delete the chime,anyone know how?
Start by making sure:
• The gearshift is in P (Park)
- The parking brake is set
• The ignition switch is in the off position
• The driver and front passenger safety belts are unbuckled
1. Turn the ignition switch to the on position. DO NOT START THE
ENGINE.
2. Wait until the safety belt warning light turns off. (Approximately one
minute)
• Step 3 must be completed within 30 seconds after the safety belt
3. For the seating position being disabled, buckle then unbuckle the
safety belt three times, ending in the unbuckled state.
• After Step 3, the restraint system warning light (airbag light) will be
turned on for three seconds.
4. Within approximately seven seconds of the light turning off, buckle
then unbuckle the safety belt.
• This will disable the Belt-Minder feature for that seating position if it
is currently enabled. As confirmation, the restraint system warning
light will flash four times per second for three seconds.
• This will enable the Belt-Minder feature for that seating position if it
is currently disabled. As confirmation, the restraint system warning
light will flash four times per second for three seconds, followed by
three seconds with the light off, then followed by the restraint system
warning light flashing four times per second for three seconds again
Just buckle it up. Chime goes right off.
Jk. Sorry I couldn't help myself. It is in the owners manual. If you fail the first time around repeat as necessary to get it done. Sometimes it doesn't work on the first attempt
It worked the first time,what i didn't know is you have to do it every time you get back in the truck lol, i was thinking it was off for good the first time.
This will be great. Roaming around the farm was really annoying with the light and chime going off in my ear all the time
