Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford SVT Raptor General Discussions [GEN 1]
Rusting Raptor Rocker panels
This is a discussion on Rusting Raptor Rocker panels within the Ford SVT Raptor General Discussions [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Hey ide be interested in a kit if your doing them? ---------- Post added at 03:06 PM ---------- Previous post ...
Like Tree154Likes
Old 05-12-2018, 11:06 AM   #231 (permalink)
Junior Member
Default Interested in kit
---------- Post added at 03:06 PM ---------- Previous post was at 03:03 PM ----------
Did you ever do kits? Ide take one for my f150.
Lyford13 is offline   Reply With Quote
Old 05-12-2018, 12:30 PM   #232 (permalink)
Originally Posted by SVT_Mayo View Post
Any way to get those plugs for the holes?
I took my steps off yesterday and the paint is bubbled on both sides under the rear mount of the steps under the door. My rocker on the passenger side is gone on the bottom, might be able to patch a section since its not up the side yet. My driver side ill be able to save.
I went to pep boys and bought clear bra material. Cut them, cleaned the surface and applied. They held up all PA winter. A couple look worse for wear but itís a 5 minutes replacement.
Swacer is offline   Reply With Quote
Old 05-12-2018, 07:59 PM   #233 (permalink)
Junior Member
I would like to get one of you still have/ doing them?
Old 05-15-2018, 08:44 AM   #234 (permalink)
rkneeshaw's Avatar
Funny, my truck is EXACTLY the same, in exactly the same spots.
2013 Ford SVT Raptor
Flutter Stacks - Fuel Offroad - Duratracs - EvoX-R 2.0 - Baja Designs - LineX
Build thread: http://www.fordraptorforum.com/f65/l...upercab-55911/
Wheelwell: 2013 Ford F-150
Fuelly: 2013 Ford SVT Raptor
rkneeshaw is offline   Reply With Quote
Old 05-15-2018, 08:11 PM   #235 (permalink)
Bulletnjm's Avatar
the running board mounts seem to be creating a rust issue for my truck
Bulletnjm is offline   Reply With Quote
Old 05-18-2018, 05:31 PM   #236 (permalink)
SVT_Mayo's Avatar
Great idea. Thank you.
SVT_Mayo is offline   Reply With Quote
Old 07-11-2018, 07:56 PM   #237 (permalink)
So has anyone actually linked the running boards to rust issues as well? Have guys without them noticed less or no rust issues?
daveypetey is offline   Reply With Quote
Old 07-12-2018, 08:47 AM   #238 (permalink)
Yukon Joe's Avatar
Seeing the inside of my rusted rocker panels, is say the running boards are not the issue. They are rusting from the inside, out. The problem stems from not being able to get water out of the rocker panel. There are small gaps along the rocker panel to let the water out, however if you have done any offroading, these small gaps are likely filled with dirt, sand, leaves, sticks, rocks, etc. Which do not allow the water to escape once it enters.
The best solution is it clean it, coat / protect it then to continue the process at an interval that you can afford.
Good luck.
Yukon
Sent from my SM-G965U using Tapatalk
daveypetey likes this.
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Boatec's Ford Raptor with New Panels RaptorAddict.com Raptor Addict 41 06-08-2017 02:05 PM
TheDoubleAA Raptor build with new style Ambient door panels TheDoubleAA Ford Raptor Interior Modifications Forum [GEN 1] 15 11-14-2014 07:43 PM
Raptor Fenders/Body Panels On Lowered F150 PacificWheel Ford SVT Raptor General Discussions [GEN 1] 31 08-18-2014 01:27 PM
line-x rocker panels vinson284 Ford Raptor Exterior Modifications Forum [GEN 1] 10 07-25-2012 09:19 AM
Thinking very seriously about Line-X for my rocker panels... Double Tap Ford Raptor Exterior Modifications Forum [GEN 1] 14 08-18-2011 07:02 PM
