Rusting Raptor Rocker panels
Sharkus29
Kickin it in Canada!
I've got enough of the parts on order for 10 kits, so if there is enough interest, I'll offer those initially in order to see how the price point works out. Once that is sorted out, I will hopefully be able to offer the kits in the For Sale section of the forum. The goal is to help other Raptor owners avoid the dreaded "rocker rot" with all of the parts they need in a single, reasonably priced kit.
All the best,
Dave
I would be interested as well
Yukon Joe
Russellville, AR
These pictures show how many holes there are to plug. When I removed the factory sealing tape, I stuck it onto the bottom of the sill to show how many salt/water entry points there are if you don't keep checking and replacing the tape all of the time.
There are also some similar holes in the front floor pan. I plan to include plugs for these too.
Correctly sized plugs for the square holes have been a bit hard to find, but I've got several samples that I'm evaluating. If I find a good fit, I'll include those in the kit too. There is one of these oddball square holes just behind the front running board mounting bracket on each side (picture below), and one in the floor pan on each side (picture above).
All the best,
Dave
The thought of salt sitting in all those nooks and crannies has cause my soul to die a little bit.....
Help out the family's that these heroes left behind fighting for YOUR Freedom.
http://www.fordraptorforum.com/showthread.php?p=840845
Donate now!
Yukon Joe
Great Lakes Raptor Excursions
www.runraptorrun.com
dhollist
SE Michigan
Final selection of the last few plugs (for the holes shown below) is underway, having talked to several potential suppliers today.
I will contact the first ten people who indicated interest in buying a kit via PM, then start making kits for everyone else after a short debug/trial to make sure the parts count, instructions, etc. are all correct.
If those ten people could provide me with feedback via PM, I would be grateful to hear about their experience with installation (generally an easy snap-in once any remaining tape is removed) and quantities of each part, especially on the SuperCab body style.
All the best,
Dave
dhollist
SE Michigan
I have a supercab do you need any pics or anything?
If you are willing to send pictures of everything from front to rear of the inner rocker panel, that would be great. It would save me from crawling around under somebody else's truck in the salty parking lot at the local mall. LOL
All the best,
Dave
07Alloy
I may be interested as well once you've figured everything out.
