The258
I need some help from the raptor gurus. I recently started having a loud grinding issue, took it to a shop and was told it was the transfer case. Got another installed and the grinding is still there, waste of $700+. Now I'm being told it's the rear diff. It sounds like it come from the back sometimes in the front, mind you I have a 2010 5.4L. since im told it's the rear diff, I'm looking into a kit, replacing the gears etc. But not upgrading gear ratio. Keeping it the same but which would be best durability wise that can handle some abuse over stock?
