Raptor Driveshaft
L
lobird91
Not that 'lucky' is an applicable word here, but you're lucky it was a front u-joint while you weren't flying down the road at 100 mph. A rear joint breaking doing what you were doing might have caused a hell of a lot more damage as well.
I would stay away from cf, as they won't hold up very well off road. There are aftermarket driveshafts out there that will be better than stock though.
Good luck!!!
After seeing the damage that had already been done other than actually replacing it before it broke, I couldn't really ask for a better outcome. Nothing is broken but the driveshaft and we all made it home safe.
RaptorEnthusiast
I admittedly do not know much about car mechanics so here goes a dumb question:
A truck is still driveable with a broken shaft?
Dane
Littleton, CO
Thanks. I always thought of the driveshaft playing a vital role in a vehicle's drivability. Learn something new everyday
David
Well it does! But if you have 4WD, you have two driveshafts - one per axle. So if you only have a 2WD vehicle, you're definitely hosed. However in a 4WD, assuming you get the shaft out of the way either by properly destroying it to where it falls out, or removing it, you now have a front wheel drive vehicle (when you are in 4WD).
I've personally driven my jeep home like this when my rear drive shaft exploded all over Highway 285 in Colorado. I've also drive the same jeep out of Poison Spider in Moab after shearing a rear pinion (and then removing the rear driveshaft).
In a pinch, it'll do! Poke your head under there - it should make sense pretty quickly.
RaptorEnthusiast
Ok so how can a shaft get destroyed? I never off-road and strictly pavement queen. Is that still a remote possibility?
Dane
Littleton, CO
Sure is! Mine self destructed on the highway AFTER a wheeling trip. Never figured out exactly why since the carnage wasn't really salvageable, but I suspect the u-joint went out, and it's kind of a chain reaction from there. Luckily it didn't pole vault on me and tear my rear end out.
What I mean by that, picture just the front part of the driveshaft coming free and falling into the pavement at freeway speed while still connected to the rear axle - pole vault.
In the OP's example, it sounds like he was goosing it on pavement and it was just too much. In fact, I'd almost wager that it'd be easier to blow one ON pavement due to the increased traction of asphalt. Your tires are more likely to spin on dirt, releasing that torque. Of course, it can be done off-road too. In some sense, blowing the u-joints is almost a best case scenario since they are cheap and easy to replace. There's always a weak point somewhere.
RaptorEnthusiast
Man I was hoping you'd give a different response lol. It's just a matter of time due to wear and tear driving on pavement it sounds like.
I wonder if a broken shaft after normal wear and tear has happened to a good number of raptor owners in general. It'd be nice if there were any mitigating factors for me to be aware of.
David
L
lobird91
assuming you get the shaft out of the way either by properly destroying it to where it falls out.
I love this quote lol, on a positive note new DS will be here today so I can move on to finding new weak links.
