Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford SVT Raptor General Discussions [GEN 1]
"No Cap" Fuel Door and Replacing the Ford Supplied Funnel
This is a discussion on "No Cap" Fuel Door and Replacing the Ford Supplied Funnel within the Ford SVT Raptor General Discussions [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
This might be obvious to many of ya, but it came as a surprise to me this morning. Glad I ...
Old 07-16-2010, 01:24 PM   #1 (permalink)
BigJ's Avatar
Default "No Cap" Fuel Door and Replacing the Ford Supplied Funnel
This might be obvious to many of ya, but it came as a surprise to me this morning. Glad I 'found out' here at the office, where I can prepare for it rather than out there hundreds of miles from anywhere...
If you look at the filler hole, you'll see there's a metal door in the way of the nozzle. You can press on this door with your finger or a pen and it wont open. It needs to be unlocked before it will move. This unlocking action is handled by the nozzle of the pump itself; the outer diameter of the nozzle engages two tabs on either side of the door (shown in the pic below, pointed at by the green arrows) and that simultaneous pressing-back action releases the door, which is then pushed out of the way by the tip of the nozzle.
If you look at our Ford supplied funnel, the neck is modeled after a pump's nozzle so the same unlock-and-push-out-of-the way action occurs when you shove it down in there.
This is all fine and good, but I have fuel cans. And these fuel cans don't have the same diameter nozzle. In the past I've used the Ford funnel in conjunction with the fuel can's nozzle and that seems to work ok (I only did this because I was using the Ford funnel as a funnel, not realizing I was unlocking the door down there also), although you'll loose some fuel and you'll be standing there for 5 minutes waiting on 5 gals to pour.
So this morning I grab myself a full sized funnel (to carry with me in my toolbox, to speed up fueling via cans and to free myself from those cans' nozzels) and I pull out the Ford funnel from the truck and shove it in a drawer never to be seen again.
Bad idea.
Thankfully, it occurred to me shortly after that I should probably test my plan before relying on it, and sure enough my funnel is a no go. The knowledge I've just shared above then came after a few minutes of figuring out why.
Here's the solution I came up with:
I cut my funnel's nose off (was a smaller diameter than the fill neck) so that it's starting diameter was slightly larger than the fuel fill's neck. I then cut a slit in the filter, angling it so that it will collapse in on itself as I press it in the neck. After a bit of tweaking, I've got it so that the collapse happens just right to still press on the tabs, unlocking the door and yet still with enough length to push the door out of the way and hold the funnel in place for hands free filling.
Moral of the story? Don't loose the Ford funnel. Or if you do (or want to replace it for reasons like mine), make sure you dial in your replacement funnel before you need it.
Hope that helps.
BigJ is offline   Reply With Quote
Old 07-16-2010, 01:49 PM   #2 (permalink)
Once you go black.......LOL
Xjrguy is offline   Reply With Quote
Old 07-16-2010, 01:52 PM   #3 (permalink)
BigJ's Avatar
Hah! You dork.
Old 07-16-2010, 04:21 PM   #4 (permalink)
bstoner59's Avatar
does it come in shmedium?
Funny, Tim sees a big black funnel and his mind goes there...
bstoner59 is offline   Reply With Quote
Old 07-16-2010, 06:13 PM   #5 (permalink)
Senior Member
Good stuff as usual Jason, thanks.
I've been meaning to buy another "Ford funnel" for some time now. It's time to do that. Does anyone know the part number? I want to make sure that I always have one in the Raptor in addition to the one I use which could easily be lost. Heck, if Jason can "lose" his fuel filler door, anyone can lose the "Ford funnel". :)
Maybe it's time for a "Ford funnel" group buy?
I also think it'd be cool to have a unique funnel product just for us. I imagine it would be a jug-shaped - like a bleach bottle with the bottom cut off - and a Ford funnel-like end (top). It would be like this and it would work in our fuel filler (who knows maybe this or a product like it works but the only way to find out is keep buying them until we find out)..
or this
Hmm, I wonder: are there dimensions that the product needs to have to function properly? If we can identify what it takes to make it work we can find out what products will work for us...
This ones for you Tim:
MagicMtnDan is offline   Reply With Quote
Old 07-16-2010, 06:23 PM   #6 (permalink)
BigJ's Avatar
Yeah there are. The OD (outer diameter) of the neck is critical, as is the length from that OD to the tip (assuming its tapered, unlike our stock funnels).
If I can dig up some calipers I'll take some measurements.
Old 07-16-2010, 06:54 PM   #7 (permalink)
Madcowranch's Avatar
Genetically Modified
diesel pumps have a nozzle with a diameter of 15⁄16 inches (23.8 mm) , unleaded gas pumps have a nozzle with a diameter of 13⁄16-inch (20.6 mm)
Madcowranch is offline   Reply With Quote
Old 07-16-2010, 08:18 PM   #8 (permalink)
Senior Member
Try to use the non-sparking calipers :mrgreen:
Old 07-17-2010, 08:17 AM   #9 (permalink)
Nacho's Avatar
Great idea. I always thought the supplied funnel was too small for bigger fuel cans.
https://lh4.googleusercontent.com/-1...htRapRain1.gif
Military Working Dog Handler US ARMY
Sadly SOLD 2010 SVT Raptor 6.2L --#3734--Oxford White--
2009 Ducati Monster 696---Pearl White---
Nacho is offline   Reply With Quote
Old 07-17-2010, 09:33 AM   #10 (permalink)
Senior Member
Thanks MCR. 13/16"
Do we now need to know the optimum length?
