No Bluetooth audio - note 8
Black_Valkyrie
Joys of a new phone. No Bluetooth audio using note 8. Ford sync latest version. Total fail.
Any ideas beyond the obvious- reset system. Unpair / pair blah blah blah?
Grrr
Aaron
Meme Corps Commandant
WA
What year is your truck? My Note 8 works perfectly with my 2010.
Aaron
WA
I had to pull my sync fuse on my 12 for the same issue
Not a bad place to go next for OP.
I'd say make sure it can pair to another vehicle if you can. That'd at least tell you which side the problem is on.
Rakimb17
SoCal
Grrr
No music or no phone calls or both?
If no music check phone settings. Samsung somtimes disables music.
Go into bluetooth settings on phone, click the gear next to SYNC and make sure Media is turned on.
B
Black_Valkyrie
Nothing that simple done all that already. Like I said - calls Yes, music no.will try fuse that the last thing to try
---------- Post added at 11:20 PM ---------- Previous post was at 11:04 PM ----------
Fuse did nothing. Looks like lots of people having same issue across other vehicles. Lame.
