I guess it is. We're becoming as bad or worse then california.
---------- Post added at 05:22 PM ---------- Previous post was at 04:53 PM ----------
This is from the NY DMV website:
Modifications that Change a Vehicle Registration from Commercial Class to Passenger Class
Vans (Part 106.3 (d)). You can register a van in the passenger class if the van has:
at least one side window behind the driver, and
at least one seat or set of seat fittings that is installed behind the driver, or
camping equipment that is installed behind the driver. "Camping equipment" indicates that you have a permanent bed, a permanent stove, or a permanent refrigerator in the vehicle. If this equipment is removed and you use the van, you must register the van as a commercial vehicle.
Pick-up Trucks (Part 106.6 (c)). You can register a pick-up truck in the passenger class if the pick-up truck complies with all of these requirements:
The pick-up truck has an unladen weight of more than 5,000 lbs. and is used for non-commercial purposes.
The pick-up truck does not have any business advertisements.
A permanent camper top completely encloses the truck bed, and which has one or more side windows.
The pick-up truck has seats, seat fittings, or permanent camping equipment that are installed in the truck bed. "Camping equipment" indicates that you have a permanent bed, a permanent stove, or a permanent refrigerator in the vehicle. If this equipment is removed and you use the pick-up truck, you must register the pick-up truck as a commercial vehicle.
The DMV cannot examine your vehicle to determine the correct registration class. You must determine the correct registration class for your vehicle.
---------- Post added at 05:24 PM ---------- Previous post was at 05:22 PM ----------
That last sentence is interesting. So according to them, If I determine that it is classified as a passanger vehicle, then it is. So all I have to do is say that I do have all those modifications and then I'm set.
