High mileage owners please check in
40oz
I have 270k Miles on my 2011, still runs, drives and performs like new! Only issues are a small crack on side of driver seat leather, dead reds on 3rd brake light and back up camera just stopped working. I'd buy one with 100k on it all day....as long as it wasn't beaten on too much...
I want you to keep checking in on this thread. 270k...I love it.
78 DESERT RAT
105,000 miles
At 105,000 Miles, Purchased used with 34,000 miles. Raptor is in the dirt at least twice a month, Truck has at least 25,000 miles off-roading best truck I've ever owned. Below is a list of items I had to fix so far.
1. Rebuilt all shocks twice, needs it again.
2. On my third set of tires.
3. On my second set of brake pads front and rear.
4. Replaced Front passenger hub---------------------76,000.
5. Replaced Alignment cams at -----------------------85,000.
6. Replaced passenger side front axle and cv joints- 88,500.
7. Had transmission calibration reset at dealer-------88,500.
8. Replaced radiator cap--------------------------------88,500.
Problem areas:
1. Drivers seat heater has never worked.
2. Rear window defroster has never worked.
3. Sometimes when I turn the key to start there is a couple second lag.
4. Front end clunk over small bumps at slow speed.
40oz
Update - I am now at 175K
So far only problem has been the check engine light "check fuel fill inlet". Sometimes the truck will die at a redlight after getting gas. Other than that very pleased.
Yukon Joe
Russellville, AR
Problem areas:
Perhaps the steering rack is going. That could be your low speed clunk.
Sent from my SCH-I545 using Tapatalk
bucktown
Biggest repair I've had was a steering rack at around 85000 miles, had the rear widow defroster around 30000, did a shock rebuild at around 70000 when one finally started leaking.
mpk1996
mines at 75000
2nd set of tires - orig replaced around 36k. The 37" toyo R/T have been good since. due to replace this spring
replaced the stock brakes at 25k. they weren't too bad, but wanted the upgrade. still looking good on the pads and rotors
had the shocks rebuilt at 65k. they are great
truck just had (well, I just figured it out) hub needle bearings go out on it. so I am replacing the axles, hubs, and IWE. I also ordered the silicone IWE vacuum lines, so those will get replaced as well.
that's been about it. I have had to replace the ballast and control box on my raptor retrofit HID headlights, but that's not a stock truck issue.
aschiller98
I have 118k miles on my truck, purchased at 85k
So far have added
1 set of tires
2 idler pulleys
1 rear wheel speed sensor (crushed wile off roading)
