I just spent an hour trying to search this issue and I know it has been covered before. Cant remember if anyone has solved the problem that is not associated with FWD not fully disengaged.
I have noticed something pops once every now and then when turning out of my driveway. There is only a single pop and sounds more like up front.
However, I only noticed this after I installed my Deavers +2's. The rear shackles are installed correctly as per the instructions and other posts on here.
More of an annoyance than anything.
I have had it up on my lift many times and everything appears normal and tight. 2014 with 6K miles.
I am also having this same issue. Only happens occasionally, on the left side and only happens when backing up after the truck has sat for a while.
This was my issue exactly. Took it to the shop that did the alignment and asked them to check the bolts. He says "he put a wrench on it and they are tight." I should have specified a torque wrench. Two of my LCA bolts backed out at RTF. Fixed it there with the help of @TMX Engineer. Took it back to the shop to get the alignment fixed and gave them the factory torque for the LCA bolts (258 ft-lbs) "That is a LOT of torque....". It hasn't popped since Jason and I fixed it. My mistake is not providing the torque value to them and asking them to check it the first time.@KaiserM715 @HAP
I picked up my truck yesterday and spoke with my Rep. there at the ford dealership. The issue that you guys are concerned about and that I had to take my truck in for was simply that the Lower Control Arm was loose, they torqued the bolts back to what they should be at and the issue was fixed. I did have to pay $166 (Labor Fee) so my advice to you guys would be to find out what the torque specs are for those bolts and then to it yourself if you are able to so that you can avoid having to pay for someone to do it.
