02-17-2011, 12:21 PM
#30 (permalink)
Famous Raptor
Register to remove these ads. It's free!
Originally Posted by FSM06
BDRAG, not to be critical, but you stated the "whine" was from the gears, which is very typical of a poor contact pattern of a gearset. You then stated that the dealer replaced the clutches, bearings, and seals. Did they replace the gearset? And if so, if the CLUNK is backlash then the backlash was EXTREMELY excessive. Backlash set within normal specs of .008" to .012" should never be felt. Just curious.
FSM
Thanks FSM!
I was gonna say the same for BDRAG's issue. The whining of the ring and pinion and chattering of clutch packs, as FSM could tell you, were another super common issue....and tsb's.
Oh and to address Silverbolt's question about installing a zerk fitting, the grease is mainly applied inside the shaft of the driveshaft, so a zerk fitted to the transfer case housing wouldn't really get the grease to where it needs to go.
6.2 | White | Method Race Wheels | Magnaflow Magnapack dumped | Kooks long tubes | AFE | 5 Star/SCT tune | ADD front bumper / custom rear bumper | Rigid Ind. 40" lightbar and Dually's | Deavers +2 | ADD/King Bumpstop kit | Viair air compressor | Line-X bedliner and fenderwells|
Rigid Ind. Project Raptor
ADD Project Raptor
Pickuptrucks.com feature article truck
Fourwheeler Magazine feature article truck
Want your Perch Mod done in AZ? PM me for a great deal!
