Question on the MAF connector? is your MAF connector, the wire with the cap that connects to the MAF, does it fit tight on your MAF to where it is snug and it don't wiggle side to side if you try to move it? I notice that on mine, it fits and snap and it also has the red tang on the bottom to lock it in, but it is very loose and it wiggles side to side. I can grab the wire right at the base of the connector and move the wire side to side and it moves the connector while plugged into the MAF. Just wanted to see if your is the same or maybe this might be part of the problem.
went home during lunch and started the truck. it started fine and drove it around the block. didn't show the symptoms, but I did not want to drive it to work and risk getting stranded. I will do that after work. I will also clean the MAF again and TB. Thanks.
