mprice1234
Gen 1 Rules
Fuel going bad in a Raptor!
From my expereince I don't think its possible for fuel to go bad in a Raptor, it gets sucked up by the thirsty 6.2 way to quickly for it to every go bad! I wonder though how the extra weight will effect the handling of the truck being fluid and moving around in the tank at the rear of the truck.
I would think the easiest way to do it is mount it in the spare tire location and have a transfer pump that turns on when you want. Just transfers the fuel in reserve into the standard tank. You would just have to make sure you use the fuel in the fuel cell on a semi-regular basis so it doesn't end up going bad.
Ideally I think you would like to have it automatically transfer fuel into the standard tank.
