Your not going to notice a difference if you change your pads. I’d buy steel braided lines first.
I have R1 rotors and pads on my 62 Impala with 800hp it stops better than my raptor and weights more I’m sure.
I have clamping power with a Hydobooster and Z06 calipers.
You need more clamping power for lack of better words the pads won’t make a difference unless you put them in wrong or something weird happened.
You really want to stop there is a guy selling a used front and rear Brembo GT kit for $4000 right now. That’s a great deal and you will def feel the difference there.
This is simply not true and is taking the thread into urban legend...
Pads most certainly can change your braking characteristics. They can be chosen for a different heat range which will reduce the fade the OP experienced. You can choose pads for low dust, low noise, low temps, high temps, street use, track use, there are literally hundreds of choices.
It is not a lack of clamping power causing his fade, it is heat build up. It builds up in the whole system. Pads fade, fluid boils, you lose braking power.
I think stainless lines are a plus, they will firm up the feel a little. Pad and rotor choice is pretty critical and we should be able to get decent braking with less than a full on Brembo kit. These are just my opinions. They were formed mostly on a road race track in a Porsche. On the track, which is way tougher than any street use, slotted cyro tread rotors worked the best for me. Race pads last a weekend at best so they are throw away.
I was turned off by Freedoms claims for the Centric ceramic pad they use because the main focus seemed to be on how long they last. That tells me there isn't as much friction as other pads that do not last as long. They do pan the R1 pads though, so the Centric should be a better choice. I can't help but think there is something better yet for performance. I intend to try the EBC yellow pads.
The other thing you could do after the braking system is sorted, including a fluid flush, is get some flex tubing and direct air right to the brakes for cooling.
My last car was a Cayenne turbo with six piston Brembo front calipers, some of the most powerful brakes on a production vehicle. I am having to make a big adjustment to F150 brakes...
