Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford SVT Raptor General Discussions [GEN 1]
Bought a 2014. Have some comments and questions.
This is a discussion on Bought a 2014. Have some comments and questions. within the Ford SVT Raptor General Discussions [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Follow up question. Is this a saftey or wear related issue or does it jost soften the ride? Sent from ...
Like Tree11Likes
Old 12-07-2017, 10:43 AM   #11 (permalink)
allenfrx's Avatar
Junior Member
Follow up question.
Sent from my SM-G950U1 using Tapatalk
allenfrx is offline   Reply With Quote
Old 12-07-2017, 10:50 AM   #12 (permalink)
AndysLog's Avatar
less ply sidewall?
lol safety breh.
allenfrx likes this.
AndysLog is offline   Reply With Quote
Old 12-07-2017, 12:32 PM   #13 (permalink)
allenfrx's Avatar
Junior Member
Interesting point. An online rep for BFG said don't run them.
There is a goodyear store up the street abd they say they swap between C,D and E on various sized F150s all the time with zero concerns.
The only exception they was was the F250 must have E on it no matter what the customer insists on.
He did say that i should probably keep these at the max 45psi at all times since they are C and Ford's door insert says 44 PSI. He said you wouldn't run these de-aired unless there were some extenuating circumstance.
I could see how that might limit off road performance and create an issue??
Old 12-07-2017, 01:13 PM   #14 (permalink)
SZDZMTR's Avatar
at 45 psi you would bounce like a pinball all over the road...
2013 SCREW TUX BLACK LOADED (MONEY PIT)
2011 SCAB MOLTEN ORANGE (SOLD)
SZDZMTR is offline   Reply With Quote
Old 12-07-2017, 02:27 PM   #15 (permalink)
allenfrx's Avatar
Junior Member
Thats the recommended cold pressure on these.
I run my sports car below pressure in the summer on purpose as it recommends 36PSI cold and when they get hot they hit 42psi. That causes you to lose traction so i run them at 31 or 32 PSI and ride around with warning lights on all the time. In the winter i air them up a but because you cant get much traction on cold tires anyway so no sense trying to gey those 4.2 second quarter miles anyway.
So how much preasure do you run in raptor? The ride feels very smooth to me.
You want bouncy? Try a GT500 with after market suspension on top of the SVT pckg
We joke that you could tell the diffetence betweem a penny, a dime or a quarter by running over with the car and once you got good you could count the change in the road along your commute by feel.....its THAT hard.
The Raptor feels like a 76 CC coupe de'ville by comparision???
Hell, its smoother than the 16 explorer i traded for it and on par with my old titan.
The roads round here are pretry rough...
One road in a particular will send my sports cars airborne and is so bad you have to fight the wheel to keep the pavement from pulling those super sport tires and driving you right in the adjacent lane...and this happens when the wheel is fixed in a perfectly straight line. You literally have to turn the wheel to the left like you are getting into the turn lane just to keep the car straight (perfromance tires are the issue. Cars with all weather tires don't seem to do it on that road)
I told my wife we finally have a vehicle we can do the speed limit on Wrightsboro road without tearing it up...
Old 12-07-2017, 02:50 PM   #16 (permalink)
RDFTS's Avatar
aka Rick
Default Bought a 2014. Have some comments and questions.
Plenty of threads on the subject here. The GEN1 door jam shows 44psi. I personally run 40psi with BFG KOs Load D or E rated tires. The door jam on the GEN2s with the tires you have will show 38psi.
I have a brand new set of KO2s Load E that will go on soon once I get my front suspension dialed in. I will run those at 40psi.
Its ultimately your decision but I would not run a lesser sidewall and Load C on my GEN1 when off-roading. Maybe if it only saw pavement and I never went above 100mph then I might consider those tires but me not going off-road or not going over 100 will never happen for me, hit close to 100 almost every day.
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR 14'/15'/16'/17' | Raptoberfest 14'/15'/16'/17' | Time Attack 14' | Snoball 15' | AR Run 15' | TRR Baja 16' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 12-08-2017, 12:20 AM   #17 (permalink)
Remember our Raptors are heavier than a standard f150
smurfskier is offline   Reply With Quote
Old 12-08-2017, 12:30 AM   #18 (permalink)
allenfrx's Avatar
Junior Member
Im going to take it in and bring it up tomorrow.
I don't normally do more than 100 in a truck...though mid 80s is common.
I am not sure how much leverage ill have to get them to order D class?
RDFTS likes this.
Old 12-09-2017, 11:57 AM   #19 (permalink)
adeerchaser's Avatar
ALWAYS carry, never tell
Good Luck on the tire issue. Regardless, Welcome and nice truck! When I had BFG's I ran them at about 42 psi. Now I run TOYO MT's.
2014 SuperCrew Ruby Red
adeerchaser is offline   Reply With Quote
Old 12-12-2017, 10:08 PM   #20 (permalink)
Snowsled's Avatar
I think you are getting bad info about the tires. Both the C and E rated version have three ply sidewalls. Both are rated for sustained use at 112 mph. The C rated tires are good for over 2500 lbs each, which is more than the Raptors GVWR. The tires themselves weigh THE SAME at 65 lbs. Tell me again about the more robust construction... The difference is the E rated version gets pumped up to 65 psi to carry an additional 700 lbs per tire.
There is no reason to not keep them and wear them out. It is more than enough tire for the truck.
2010 Black 5.4 Lux, roof, Sony etc. Showroom Stock
Snowsled is offline   Reply With Quote
Questions on 2014 Black special edition snooky 2014 Ford SVT Raptor Forum (Reply Only) 9 11-20-2013 10:40 AM
First self oil change comments Madcowranch Ford Raptor Maintenance Forum 27 07-24-2011 11:51 PM
Warns comments dbmaster Ford Raptor Exterior Modifications Forum [GEN 1] 3 07-12-2010 09:12 PM
