Bedsides spread help
demnraptor
Humble, TX
Ok so at Raptoberfest my bedsides spread quite a bit. I plan on buying the TMX bed stabilizers but was curious if anyone had a way of pulling the top portion back in so I can mount the stabilizers and "fix" the problem?
BAJASVT
SE Michigan
There are stake pocket holes in the steel bedsides below the plastic bedrail caps. Pop up the plastic cap at the rear of the bed to access the pockets and pull the bedsides together with a ratchet strap.
