AUX Switches - what are yours used for?
Mark Ducati
I was trying to think of what accessories I might use the AUX switches for...
I wanted to use one for a DMH cutout, but still trying to figure out if the switch would work or not... in my other thread, it was suggested to use 1 switch to open the valve and then use a 2nd switch to close it.
So, if that's possible and I use two switches... That leaves me with two, just trying to figure out what I might use them for.
The only things I can think of is:
-Light bar on front
-Winch on front
-Lights on rear
So, what are you running off your AUX switches?
Raptor2010
PA
Aux #1-light bar with driving lights
Aux#2- light bar with long range lights
Aux#4- fender SVT lit up.
Looking to use aux#3 for rear lights or bed LED lights
BDRAG
HAhahaaaa.
Dallas area
-Light bar on front
-Winch on front
-Lights on rear
Aux 1 = Amber fog lights
Aux 2 = Driving lights.
Aux 3 = rear lights some day.
Aux 4 = LED interior lights at some point.
Split the dual lights into the two different switches so I can run one bulb or two in each light. I can go white, yellow or both on for all on.
BDRAG
SPRSNK
I Void Warranties
Franklin, TN
Aux 4 for roof and bumper lights. Winch and jumper cables are hard wired in.
Aux 3 will be for the rear D2's.
Crosstx
Midland TX
so far im only using AUX#4 for these...
to be installed...
VIAIR air compressor w/ 3gal tank to AUX#1
LED lighting in bed rails on AUX#3
Power invertor on AUX#2
:birgits_tiredcoffee
stxraptor
SWITCH #1 - amber warning led lights in the grill and the rear.
SWITCH #2 - air compressor shut off switch
SWITCH #3 - NOT USED (yet)
SWITCH #4 - aux lights 4 square PIAA driving lights mounted in the bumper opening.
SWITCH #1
SWITCH #2
SWITCH #4
