Black_Valkyrie
- Joined
- Jan 8, 2017
- Posts
- 298
- Reaction score
- 63
Just finished my fog light install....
Amazon.ca (not .com) has the actual rigid light bracket mispriced for $30.77 canadian (which is like $20 usd). Just got mine but the price keeps changing so as stick depletes can't guarantee the price will still be so low.
Rigid Industries 40235 Fog Light Bracket for Ford Raptor https://www.amazon.ca/dp/B007NKXF5M/ref=cm_sw_r_cp_apa_aEX3yb1SWRHVX
Now.... the rigid kit is a legit kit that ships with all mounting hardware, instructions and a complete wiring harness. (Do not attempt this with a fake Chino bracket)
To complete my cheapo install I picked up 4 Chino fake ip67 rated fog lights for a total of $38 canadian. The Chino fakey fogs ship with bare ends so I went to the local electronics wholesaler and bought 4 female connectors. The rigid kit harness ships with waterproof Deutsche DT 2 pin connectors so you can easily for an extra $12 kit out all 4 fake fogs with the correct plug and play connector turning your Chino gear into (more) real gear.
Now... before I hear any whining about how dare I blah blah use fake lights - sadly I'm a lighting designer by profession and basically spend my life figuring work arounds like this for the Film industry - finding low cost equivalents that have the same or similar performance to the real deal.
So there you go... for about $55 usd I installed a "hybrid" rigid fog light system. For good measure I installed floods for the outboard units and spots for the inboard.
Link to fakey lights...
Lightfox 2Pcs 4Inch 18W Spot LED Fog Light CREE Cube https://www.amazon.ca/dp/B01M0V19ZL/ref=cm_sw_r_cp_apa_rLX3ybM00JH6Y
Lightfox 2Pcs 4Inch 18W Flood Cree LED Light Bar https://www.amazon.ca/dp/B01N0AXK4C/ref=cm_sw_r_cp_apa_kMX3ybPC606SG
And so there aren't too many tears, the giant light bar is a "real" baja designs unit. But remember- regardless of brand, real or "fake" all this stuff is made in the same factory in China.
Hope this helps someone! At the very least the rigid mounting kit is 75% off.
