DirtNasty
- Joined
- Mar 5, 2011
- Posts
- 1,320
- Reaction score
- 225
Anyone have any idle what the gallon per hour idle rate is on the 6.2l?
I am waiting for class to start idling with AC on.. Right now I am averaging 0.1 gallon for every 10 minutes.. So aproximately 0.6 gallons per hour with AC on..
-Greg
After 20 minutes idling with AC on..
So if this is accurate.. You could idle you SCrew for 60 hours... (36 gallons/0.6 gallons per hour = 60 hours)
Little dip... After 29 minutes 44 seconds 0.3 gallons used...
Isn't bad or harmful for the engine to idle for too long?
Gas engines, yes. Diesel, no. Once in a while... it probably won't do much except empty your wallet
