Hey there, I bought a brake line kit and got to installing it this week. The kit came with two part rear brake lines. The connection, on the rear axle does not come apart. My mechanic looked into it and said it's a one piece line.
Can anyone validate this for me?
thanks
Marc
I'm not exactly sure what you are asking, but on my 2011 the rear has a line from the steel, non-flexible line along the frame down to the axle. Then a second line from the axle to the wheel. At each connection, the line unscrews like normal. The axle lines are held in place with a spring clip. Maybe the 2014 changed something, but I doubt it. They are on the axle on the driver's side, so if you only looked at the passenger side I see how you could miss them.
The only issue I had was connecting the new line at the axle was very tight. I felt like I was stripping it at first, but then it worked.
I have the Alpha1 lines and I know SDHQ makes them as well. If you bought one of those kits, both companies are very responsive to customers and you can call them and they'll help you out.
