Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Tech Forums > 2011 Ford SVT Raptor Forum
Sponsored Ads
Disable seatbelt alarm?
This is a discussion on Disable seatbelt alarm? within the 2011 Ford SVT Raptor Forum forums, part of the Ford Raptor Tech Forums category!
Register to remove these ads. It's free! Is there an easy way to disable the annoying seatbelt alarm? I know ...
Like Tree2Likes
Old 02-03-2012, 07:56 PM   #1 (permalink)
PEZ's Avatar
PEZ
Default Disable seatbelt alarm?
Is there an easy way to disable the annoying seatbelt alarm? I know I should wear it all the time, but there are times when I choose not to. My F250 had a crazy procedure in the manual that disabled it. Do we have a way?
Ordered on 2/12 -> 2011 Raptor SuperCrew
2010 HD Street Glide
2010 KTM 300 XC-W
2004 Yamaha R1
PEZ is offline   Reply With Quote
Old 02-03-2012, 08:01 PM   #2 (permalink)
Yes there is. Do a search
Humvee21 is offline   Reply With Quote
Old 02-03-2012, 08:42 PM   #3 (permalink)
Maxx2893's Avatar
Rock and Roll Offroad
In the manual. Probably the same way. Includes click and unclicking several times and waiting and doing it again
The UAV (Urban Assault Vehicle): 2010 Tux Black 6.2, Top Perch, ADD Stealth Bumper, Rigid 40" E Series, Vision X Solstices, Volant Cold Air Intake, Blue SVT Vent, Dumped Magnaflow Magnapack
Maxx2893 is online now   Reply With Quote
Old 02-03-2012, 08:53 PM   #4 (permalink)
NickPic83's Avatar
Full Throttle Member
look at page 183-184 in the owners manual.
NickPic83 is offline   Reply With Quote
Old 02-03-2012, 08:54 PM   #5 (permalink)
PEZ's Avatar
PEZ
Thanks, I found it in the manual. Others can find it as well. Search for "belt minder" in the index.
2010 KTM 300 XC-W
2004 Yamaha R1
Old 02-03-2012, 09:04 PM   #6 (permalink)
RaptorSCrew's Avatar
Real Simple Way - Buckle Up
RaptorSCrew's Galleries
RaptorSCrew is online now   Reply With Quote
Old 02-03-2012, 09:05 PM   #7 (permalink)
Blind1's Avatar
Even doing the procedures does not totally get rid of the annoying reminder. Especially if you're are using a remote start. My still dings 3Xs after doing the owner's manual procedures. PITA
2011 Raptor Screw, Lux w/Nav, Tow, LineX Bedliner & Rear Wheel Wells, 55" UWS Wedge w/Notch Tool & HiLift Jack Mounted, Stubby Antenna, K&N drop in Filter, Husky Underseat Cargo Liner, 20" M&R LED Light bar, SDHQ ABS Guards, DZ Tailgate Assist, Onboard Viair 450C Air Compressor, Cargo Rail System, Stock Exhaust w/turndowns, & SDHQ Frame Reinforcement Kit
Blind1 is offline   Reply With Quote
Old 02-03-2012, 10:57 PM   #8 (permalink)
BOJANGLES's Avatar
Administrator
Its in the manual as stated above, but I basically detailed how to do it in post #10 of this thread:
Seat Belt - What's the Ford Part # (I want to turn chime off)
Originally Posted by BOJANGLES View Post
Just did mine. I slow cruise the job site a lot of the day in my truck and other superintendents are constantly hopping in and out of shotgun... The seatbelt chimes were driving me nuts! For those of you too lazy to open up the manual to page 181, here's how you disable the BeltMinder chime:
Before following procedure make sure that:
-parking brake is set
-gearshift is in park
-the ignition is in off position
-the driver and front passenger safety belts are unbuckled
1. Turn the ignition switch to the ON position (do NOT start the engine)
2. Wait until the safety belt warning light turns off (approximately one minute)
STEP 3 MUST BE COMPLETED WITHIN 30 SECONDS AFTER SAFETY BELT WARNING LIGHT TURNS OFF
3. For the seating position being disabled, buckle then unbuckle the safety belt 3 times, ending in the unbuckled state
(after step 3, the restraint system warning light (airbag light) will be turned on for 3 seconds)
4. Within approximately 7 seconds of the light turning off, buckle then unbuckle the safety belt.
This will disable the BeltMinder feature for that seating position. As confirmation, the restraint system (seatbelt) warning light will flash 4 times per second for 3 seconds.
At this point, you're golden. Do the same thing on the other side and then your seatbelt-chime-woes are a thing of the past. The serenity of silence is well worth the short time this process takes.
You can re-enable the seatbelt chime at any time by repeating this process.
As stated above, this process is a better alternative to putting a dummy latchplate into the buckle to avoid the chime, because using a dummy latchplate may adversely affect your airbag system.
****FordRaptorForum.com, it's staff members, and affiliates do not encourage you to operate your Raptor without wearing a seatbelt. This post is merely a how-to summary from the instruction manual; drivers/owners choosing to follow this procedure do so at their own risk. Please see manual (p. 181) for all applicable warnings and safety instructions.
whitelightning and knine like this.
I Get Dirty at FordRaptorForum.com
6.2 | Custom ADD Stealth Front Bumper | Rigid Industries LEDs (White 40" Amber 40" & White D2s) | Deaver +2" Rear Springs | Method Race Wheels | General Grabbers | Top Perch | Matte Black 3M Vinyl | 20% 3M Tint Everywhere + Eyebrow | islandhopper Door Badges | WeatherTech Floor Liners & VentShades | CravenSpeed Stubby | ADD ABS Sensor Guards | Custom White/Black Ford Emblems on Tailgate & Steering Wheel | 3M Red Coral SVT Logos at Fender Vents | White PCP Spider Rock Guard on Rear Diff. | Removed Swaybar | Matte White Sideview Reflectors | Escort 5900ci PassPort with GPS, Laser Shifters, & Hidden Install | Viper 5902 w/ Remote Start, Tilt Sensors, Killswitch, & LCD Remote | Custom Black TX Plates | Spyder Angel Eye Headlights w/ 6000K HIDs | Crow Enterprizes Harness Pads | VIAIR 450P Air Compressor w/ ADD Mount Behind Grille | aFe Cold Air Intake
Originally Posted by BDRAG View Post
Read, laugh and learn from an old fat fuck from Texas. HAhahaa.
BOJANGLES is offline   Reply With Quote
Old 02-04-2012, 08:27 AM   #9 (permalink)
knine's Avatar
As an experienced accident reconstructionist I can tell you first hand, over and over, the benefits of wearing a seatbelt and I always do, when driving on the road. When on the (flat as a pancake) farm, hauling rocks out of the field, etc I like the disabled feature because the reminder is annoying when starting, stopping, entering and exiting the truck every five feet. Thanks for posting.
Hey there, voter ! Do you remember that on inauguration day (Jan 20th) 2009, the national average for a gallon of gasoline was $1.78 ? Hows that "Hope and Change" working out for you ? Anyone But Obama, Nov. 2012
Originally Posted by Quicksand View Post
If members want to help me/us....Please dont re-elect OBAMA! Ur an IDIOT and deserve to be banished to China forever if you do.
knine is offline   Reply With Quote
Old 02-04-2012, 10:18 AM   #10 (permalink)
I wanna Raptor's Avatar
Wear your seat belt!! Mom said!
I wanna Raptor is offline   Reply With Quote
How do I disable the seat belt alarm? Atticus New Member Check-In 3 09-04-2011 03:15 PM
How To: Disable / Enable the Belt Minder(TM) Chime (Seatbelt reminder / bell / ringer / annoyer) BigJ Ford Raptor Audio/Video/Electronics Forum 5 11-13-2010 08:16 AM
Combined key and door/alarm AndyR Ford Raptor Forum General Discussions 12 08-18-2010 12:00 AM
problem with seatbelt locks while off-road. The Tank Ford Raptor Forum General Discussions 5 08-17-2010 12:59 PM
Fully Driven Auto Network
