12-06-2011, 09:29 PM
#14 (permalink)
Just cruisin'
Originally Posted by screamineagle08
Final outcome of raptor engine noise,,, ford bought it back after 4 plus weeks in service,, ford WOULD NOT replace the engine, ......
Sorry you had to go through this........but if I understand you correctly (and that's a big "if"), Ford is buying the entire truck back from you. If you get past being (rightfully) hacked off, I hope you do consider buying another one for reasons already mentioned. Speaking as a scientist (which is what I do for a living).....and, again, if I understand you correctly.....I think Ford ultimately did the right thing in buying back your truck. As noted in a post above, this is a fairly new motor..........something appears to have gone dreadfully wrong involving the motor in the truck you purchased. Were I Ford, I would want the motor back to tear it down, or whatever I had to do, to find out what went wrong so I could reduce the chances of the same thing happening in the future. But, since I don't know if what went wrong involved only the motor, pulling the motor from your truck and replacing it for you does me (Ford) no good if the problem involved the motor and/or it's interaction with other components (tranny, etc., etc.).....so, as Ford, I want the entire truck to work with if I want to do it right (and kudos to Ford for ultimately doing this....what was it that Churchill said...something like "America will always do the right thing, but only after having exhausted all other possibilities").
Tundras are nice trucks but, heck, I see a zillion of them around here.....nice, bland truck that's probably well-engineered......but it ain't a Raptor.
Whatever you decide, I hope things ultimately work out well for you!
ernie
