Mark Ducati
- Joined
- Mar 25, 2011
- Posts
- 294
- Reaction score
- 8
Hi All,
I have a DMH electric cutout, and Hennessey Performance sent me their "control module" to allow me to use it with one of the AUX switches.... unfortunatley (even thought I told Hennessey I was using a DMH cutout), they sent me a Quick-Time-Performance control module and the two are incompatible!
So I have to return it to Hennessey!
So, I'm going to have to simply install the DMH cutout with their switch as is...
xBX, when you installed your switch like this:
Where did you tap the red wire into 12V power? Was the gray DMH cord long enough to reach the interior cabin? How did you get the gray power cord into the cabin? Where did you ground the black wire?
I also so another picture here where a member mounted the DMH cutout switch on the back side (facing forward) of the AUX switch panel... it was stealthy, you couldn't see the switch, but it was easily found by your fingers... so how do I find a 12V switched wire for the red wire and then ground the black wire?
Again, how do I get the gray power cord through the floor of the truck into the cabin?
Thanks, Mark
Thanks, Mark
