10-14 & 17+ Raptor ABS and Vacuum Guards
SDHQ
GILBERT, AZ
Just got around to some test fitment and confirmed that our 2010-2014 Raptor ABS and Vacuum Guards do fit the 2017 Raptors as well!
SDHQ presents an inexpensive piece of protection for your Raptor ABS rear sensors and your front vacuum input!
These guards can save you upwards of $500 if you knock your factory ABS sensors while offroading.
We designed these to be an easy bolt on mod that can be knocked out in under 30 minutes easily. The four guards come powder coated and are designed to reuse your factory hardware (an upgrade to grade 8 hardware is available).
https://sdhqoffroad.com/collections...urrent-ford-f150-raptor-abs-and-vacuum-guards
