Flat towing a 2017?
treynor
Hey everyone,
I've a question about the '17s which I cannot find an answer to inline or via Ford. All new 4x4 F150s may be flat towed -- that is, pulled behind an RV or other tow vehicle - with all 4 wheels flat on the ground, but putting the transfer case and transmission in N. However, it is possible that the Raptor is an exception to this rule because it has a different transfer case and diff than regular F150s. The Raptor owners manual supplement is not available online for me to check.
Does anyone have the definitive answer?
Thanks!
Ben
T
treynor
OK, that didn't get a flood of responses :) How about this - does anyone have access to the 2017 Raptor owners' manual supplement, either in paper or online form? A pointer would be most welcome!
Thanks,
Ben
Dane
Littleton, CO
Maybe a dumb question, but how do you put the T-case in neutral on the Raptor?
Easy enough on my TJ, but the Raptor?
T
treynor
Why would it not be able to be pulled in Neutral? If you are worried, I would contact Ford & ask them.
The gen-1's could not be flat towed; something about their transfer case and diffs using clutches rather than a mechanical disconnect. I did try contacting Ford already, and at least through the avenues available to me (their helpline), they do not know :/
Raptoe13
Chickasha, OK
[quote name="Addictive Desert Designs" post=1063968]Why would it not be able to be pulled in Neutral? If you are worried, I would contact Ford & ask them.[/quote]<br />
<br />
You can tow a gen 1 on four wheels. Special procedure has to be followed, more than just putting trans case in neutral. It's in the owners manual.
Sent from my SAMSUNG-SM-G935A using Tapatalk
T
treynor
I found the definitive answer (YES) in the Raptor supplement to the F150 owners' manual. Many thanks to James Ford of Half Moon Bay for getting me the answer:
Follow these guidelines if you have a need
for recreational towing, such as towing
your vehicle behind a motorhome. We
designed these guidelines to prevent
damage to your transmission.
Your Ford Performance vehicle can be put
in neutral tow (Recreational Towing Mode)
by placing the transfer case in its neutral
position and engaging the
four-wheel-down towing feature. Perform
the steps outlined in the following section
after positioning your vehicle behind the
tow vehicle and properly securing them
together.
Note: Make sure you properly secure your
vehicle to the tow vehicle.
1. Put the ignition in the on position, but
do not start the engine. If your vehicle
has an ignition key, turn the key to on.
If your vehicle has intelligent access,
press the engine START/STOP button
once without pressing the brake pedal.
2. Press and hold the brake pedal.
3. Rotate the four-wheel drive switch to
2H.
4. Shift the transmission to position N.
5. Enable Neutral Tow through the
information display by selecting
Settings from the cluster menu.
6. Then select Advanced Settings.
7. Then select Vehicle.
8. Then select Neutral Tow.
Note: If completed successfully, the
information display shows NEUTRAL TOW
LEAVE IN N or NEUTRAL TOW ENABLED
LEAVE TRANSMISSION IN NEUTRAL.
This indicates that your vehicle is safe to
tow with all wheels on the ground.
Note: If you do not see the message in the
display, you must perform the procedure
again from the beginning.
TornadoRaptor
NY
You drive the RV, your friend will drive your Raptor, problem solved. Every Raptor owner surely has a friend who wants their truck. They'll settle on following behind you, that's for sure.
Kenny008
Knoxville, TN
Treynor, was James Ford able to point you to an on-line version of the supplement? I've been looking, but I haven't seen it available yet.
