Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Where to get +12v remote turn on wire?
This is a discussion on Where to get +12v remote turn on wire? within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Originally Posted by jdowens1 When you remove the audio module there is a connector in the back that has about ...
Like Tree1Likes
Old 12-30-2011, 06:29 PM   #21 (permalink)
BIRDMAN's Avatar
Administrator
Originally Posted by jdowens1 View Post
When you remove the audio module there is a connector in the back that has about 15 wires going to it. there is a grey wire with violet tracer that is going to be hot with the key in start or run position. There is also a blue wire that is the delay accessory wire so you will have 12volts with the key on and running then it will stay powered up when the key is off with the radio and when the radio shuts off so will the amp.
where might i find the audio module?
Help Support FRF - Become A FRF Supporting Member!
Get Your FRF Decals
Play slow pitch softball? Check out Softball Forum!
BIRDMAN is offline   Reply With Quote
Old 12-30-2011, 07:00 PM   #22 (permalink)
IRONMAN's Avatar
Super Moderator
In the truck!
IRONMAN is offline   Reply With Quote
Old 12-30-2011, 07:05 PM   #23 (permalink)
BIRDMAN's Avatar
Administrator
Originally Posted by IRONMAN View Post
In the truck!
alright smartass, where is my truck?
Get Your FRF Decals
Old 12-30-2011, 07:20 PM   #24 (permalink)
IRONMAN's Avatar
Super Moderator
Right where you left it.
Old 12-30-2011, 07:23 PM   #25 (permalink)
dataustin's Avatar
Bird, check out the following URL....
Octave 2011 FORD F150 RAPTOR DynAudio build *pic intensive* - DIYMA.com - Scientific Car Audio - Truth in Sound Quality
I think his photos are out of order, but half way down he shows a fuse box photo.
dataustin is offline   Reply With Quote
Old 12-30-2011, 07:28 PM   #26 (permalink)
BIRDMAN's Avatar
Administrator
you mean with his nav unit pulled out? that's what i'm trying to avoid...
Get Your FRF Decals
Old 12-30-2011, 07:37 PM   #27 (permalink)
dataustin's Avatar
Ditto on dismantling. I was referring to the photo where he claims to tap into power controlled by the ignition. Maybe I read it too fast.
Old 12-30-2011, 07:46 PM   #28 (permalink)
BIRDMAN's Avatar
Administrator
no, you're right. i missed it. does anyone know what fuse this is and what type of tap that is?
Get Your FRF Decals
Old 12-30-2011, 10:09 PM   #29 (permalink)
Found this - should help
ATC Add a Fuse Circuit
The ATC fuse block extension plugs into an occupied or vacant fuse slot and turns it into two circuits. Perfect for adding a circuit to an existing fuse block. Holds 2 ATC fuses. Includes an output wire for the added circuit with a butt splice on the end for easy circuit integration.
ATM Add a Fuse Circuit
The ATM fuse block extension plugs into an occupied or vacant fuse slot and turns it into two circuits. Perfect for adding a circuit to an existing fuse block. Holds 2 ATM fuses. Includes an output wire for the added circuit with a butt splice on the end for easy circuit integration.
Click on this below:
Fuse Holders
Stepside is offline   Reply With Quote
Old 12-31-2011, 01:48 PM   #30 (permalink)
BIRDMAN's Avatar
Administrator
I bought this today. Should be easy to plug in to a fuse on my passenger side kick panel and run te wire under my door sill panel back to my amp.
Sent from my right thumb using Tapatalk.
Get Your FRF Decals
Tags
12v, amp, ford raptor, fuses, remote wire
What's the blue wire for? Bullishone Ford Raptor Lighting Modifications Forum [GEN 1] 7 10-05-2011 11:10 AM
How to wire rear lights? whtrapta Ford Raptor Lighting Modifications Forum [GEN 1] 24 06-13-2011 11:05 PM
TSB 10-13-4: 2010 Ford Raptor SYNC Non-Navigation - No Turn By Turn and/or Unable to Find Location BigJ Ford Raptor Problems and Questions Forum 0 05-26-2011 01:12 PM
New wire thru firewall FlounderStalker Ford Raptor Audio/Video/Electronics Forum [GEN 1] 12 06-27-2010 01:39 AM
Upfitter wire access? BigJ Ford Raptor Audio/Video/Electronics Forum [GEN 1] 7 03-23-2010 03:25 PM
