Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Where to get +12v remote turn on wire?
This is a discussion on Where to get +12v remote turn on wire? within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
I need to tap in to get a 12v amp turn on wire when the ignition is switched on. I ...
Like Tree1Likes
Old 12-30-2011, 12:47 AM   #1 (permalink)
BIRDMAN's Avatar
Administrator
Default Where to get +12v remote turn on wire?
I need to tap in to get a 12v amp turn on wire when the ignition is switched on. I don't want to use an AUX switch. Any thoughts?
Help Support FRF - Become A FRF Supporting Member!
Get Your FRF Decals
Play slow pitch softball? Check out Softball Forum!
BIRDMAN is offline   Reply With Quote
Old 12-30-2011, 08:03 AM   #2 (permalink)
IRONMAN's Avatar
Super Moderator
you going to run both amps? If not steel it from your other amp/sub.
If you are running both maybe use a relay and have it triggered by the stock amp but run another power wire from the battery.
IRONMAN is offline   Reply With Quote
Old 12-30-2011, 09:31 AM   #3 (permalink)
BIRDMAN's Avatar
Administrator
the stock sub amp(i think) has constant 12v power. i stuck my tester in the harness and it was showing voltage with the truck off
---------- Post added at 09:31 AM ---------- Previous post was at 09:28 AM ----------
the stock sub amp harness has 5 wires: 12v constant power, ground, 5V remote turn on(not enough for my new amp) and the + / - speaker leads. i stuck my tester in the +12v wire in the harness and it was showing voltage with the truck off.
my JL amp does have a feature where it will auto turn on when it senses voltage through the speaker leads but they manual recommends using that feature only when absolutely necessary because it's not as reliable as a hard wired 12V remote wire.
Get Your FRF Decals
Old 12-30-2011, 09:32 AM   #4 (permalink)
IRONMAN's Avatar
Super Moderator
Hmmmm. Really?
I would think that would drain the battery but what do I know.
Old 12-30-2011, 09:35 AM   #5 (permalink)
Hockster's Avatar
My 45ft Bluewater Party
What Iron said or what about the rear power supply. Easy to get to and its fused with a 30
Hockster is offline   Reply With Quote
Old 12-30-2011, 09:36 AM   #6 (permalink)
BIRDMAN's Avatar
Administrator
Hmmmm. Really?
i responded to your question in a bass-ackwards way. the stock amp does have a remote turn on(therefore it's not "on" when the truck is off) but the stock remote turn on is only 5V and will not be enough to trigger my aftermarket amp.
---------- Post added at 09:36 AM ---------- Previous post was at 09:36 AM ----------
the rear "cigarette lighter"?
Get Your FRF Decals
Old 12-30-2011, 09:38 AM   #7 (permalink)
IRONMAN's Avatar
Super Moderator
The rear cig lighter has constant power. I use it to run my security camera but I use a switch to turn on and off.
Old 12-30-2011, 09:46 AM   #8 (permalink)
BIRDMAN's Avatar
Administrator
that's what i thought. did Hock mean something else?
Get Your FRF Decals
Old 12-30-2011, 09:48 AM   #9 (permalink)
Hockster's Avatar
Hmm.. Ok.. Thought it was like the front... Well then how about the front power supply... and ya its not a cig lighter and more come bird get with the times!!! ha ha ha ha ha.....
Old 12-30-2011, 10:11 AM   #10 (permalink)
BIRDMAN's Avatar
Administrator
how would i gain access to the feed wires to the front power supply? couldn't I just splice in to the fuse with a 16g wire?
Get Your FRF Decals
Tags
12v, amp, ford raptor, fuses, remote wire
What's the blue wire for? Bullishone Ford Raptor Lighting Modifications Forum [GEN 1] 7 10-05-2011 10:10 AM
How to wire rear lights? whtrapta Ford Raptor Lighting Modifications Forum [GEN 1] 24 06-13-2011 10:05 PM
TSB 10-13-4: 2010 Ford Raptor SYNC Non-Navigation - No Turn By Turn and/or Unable to Find Location BigJ Ford Raptor Problems and Questions Forum 0 05-26-2011 12:12 PM
New wire thru firewall FlounderStalker Ford Raptor Audio/Video/Electronics Forum [GEN 1] 12 06-27-2010 12:39 AM
Upfitter wire access? BigJ Ford Raptor Audio/Video/Electronics Forum [GEN 1] 7 03-23-2010 02:25 PM
