Rog it's the same exact thing as the pic in post #28. you plug the black fuse holder in to the fuse box, plug the "stock" fuse back in to one terminal, and then another fuse for the accessory line which runs right out. It separates the circuits with 2 different fuses which is what I was concerned about. this way if my amp wire shorts it won't blow my ignition, just the accessory fuse.
I'll have to keep this thing in mind, talk about easy.
no kidding. it almost seems TOO easy. especially since i can get right behind that kick panel and pull the door sill off. did you have any trouble removing your door sills that time you pulled them off?
They are kinda a bitch, the clamps have hooks in them so get close to the hook and pry with a screw driver gently.
Fuse location I used for a switched 12v source ... only downside is now you can't put the fuse cover back on.
According to the owner's manual, the ignition switch is the 15 amp next to the one I'm using. The one I'm using is the delayed accessory (110V power point and AM/FM radio). Although, I'm not noticing any delay. I use it to run a digital voltmeter and it switches on and off with the ignition. Using a 10 amp fuse. I can't recall why I didn't use any of the spare fuse locations ... maybe no power running to them. I believe I used this fuse because it didn't cover up any other fuses.is that the ignition fuse? what size fuse did you use for the remote wire? is it possible to use one of the 5-6 "spare" fuse locations instead?
