What's this?
Raptized
Raptized
Raptorida
Attached picture is upside down. On the passenger side under top rail.
RaptorMaryland
Maryland
Ambient air temperature sensor
with some software I can turn that into a Missile Launch Detector. Detect Heat bloom, show Missile Launch on screen.
But you will still have to Launch your Countermeasures.
A good Countermeasure?
As side window goes down, take long last drag on your big Cuban Cigar
Toss Cigar out to decoy Missile.
Then and only then brake hard into a right or left turn away from Cigar to get out of the blast zone.
Raptized
Raptized
Raptorida
Would it affect the displayed temperature if I moved it lower to the ground approximately the same distance from the radiator?
Jimbo
Mad Frog Mattis
IL
Potentially, but only while you're stationary. The heat from the pavement/asphalt will affect the reading. Once you start moving, you'll be fine.
Raptized
Raptized
Raptorida
I just moved the horns and the sensor. What a difference. I will post a how to on my build thread. It was easy and took ten minutes. Before and after. a298cf8e2144019903915bb1cc6eb379.jpgbdcae77759ea812a2b75dc5b879b495c.jpg
Sent from my SAMSUNG-SM-N900A using Tapatalk
