Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Upgrading stock OEM trans cooler
This is a discussion on Upgrading stock OEM trans cooler within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Im thinking buy a second stock cooler and have a Rad shop make one out of the two. I have ...
Like Tree101Likes
Old 08-31-2012, 06:50 PM   #21 (permalink)
fordfan's Avatar
Im thinking buy a second stock cooler and have a Rad shop make one out of the two. I have a guy that does all our Rad work and does very nice work and very reasonable.
Silver 13 ordered loaded with everything except box graphics with a pile of toys to install when it gets here!!!
fordfan is offline   Reply With Quote
Old 09-01-2012, 12:19 PM   #22 (permalink)
PropDr's Avatar
Simply adding a second cooler would not be a good idea, the pressure drop would almost double.
Grafting two coolers together would drastically reduce the pressure drop and that is a good thing.
PropDr is offline   Reply With Quote
Old 09-01-2012, 01:56 PM   #23 (permalink)
cups's Avatar
I'm confused. I can see "adding" a second cooler in series may be too much pressure drop or dp. So what about plumbing it to be in parallel?
What do you mean by "grafting"?
cups is offline   Reply With Quote
Old 09-01-2012, 02:08 PM   #24 (permalink)
cups's Avatar
And another thing!
Deleted
Sorry. Lack of sleep. Just woke up and the first thing that came to mind was this stupid post. This topic is important to me and I don't want to derail it.
Old 09-08-2012, 11:35 AM   #25 (permalink)
Kowboy17's Avatar
Could it be that Ford with all their desert testing, specific building etc that the tranny temp is o.k. running at 204? I just can't think that these engineers built this truck without thinking.."hmmmm, wonder if 204 is the correct temp".
With all that said, I may be out of my mind!
hkguns likes this.
Kowboy17 is offline   Reply With Quote
Old 09-09-2012, 10:28 PM   #26 (permalink)
I'm worried about it because I am adding a super charger and almost doubling torque output of the engine. More torque = more heat in the transmission.
195-205 is correct temp for the transmission, but it can be exceeded if you push the truck.
new Mustangs are the same way. Push em hard around a road track for 2-3 hours and they start to overheat. stock cooling system just cant keep up.
I have had no luck in locating a heat exchanger core that will drop into the existing bracket easily. Going to get a Tru-Cool 40,000 BTU cooler off ebay and plumb it in place of the stock cooler with 160* bypass valve. Will just require a little custom bracket made up.
rbarn is offline   Reply With Quote
Old 09-09-2012, 10:53 PM   #27 (permalink)
Macman's Avatar
Interesting topic, look forward to seeing if there is a cheap solution.
2012 SVT Ford Raptor Screw - Blue Flame Metallic
2013+ FX4 HIDs|RPG Stage II|Undercover Flex|40" LED Bar|Method NVs|Mid Perch|
1969/77 Ford Bronco
2002 Honda s2000
Macman is offline   Reply With Quote
Old 09-11-2012, 02:49 PM   #28 (permalink)
Kowboy17's Avatar
Rbarn, then you are correct, keeping it cool with that setup is a smart and prudent move. Keep us updated!
hkguns likes this.
Old 08-30-2013, 12:27 AM   #29 (permalink)
m3dragon's Avatar
SDHQ Ford Raptor Bolt On Transmission Cooler
Is this the resolution or is there better options?
m3dragon is offline   Reply With Quote
Old 08-30-2013, 08:10 PM   #30 (permalink)
Dan06's Avatar
Other than the brackets and hoses what is the difference between SDHQ's cooler and the CBR mini cooler (other than price)?
http://www.cbr-performance.com/page3/page24/page24.html
Dan06 is offline   Reply With Quote
Ford Raptor Console-to-Cooler Conversion raptorort Ford Raptor Interior Modifications Forum [GEN 1] 18 10-30-2012 04:05 PM
Trans fluid? STUTIDE Ford Raptor Problems and Questions Forum 2 07-23-2012 06:18 PM
Mystery of the Disappearing Cooler E63 Ford Raptor Photos & Videos 0 07-05-2012 10:59 AM
Anyone else have this trans issue? MikeD Ford Raptor Problems and Questions Forum 10 05-17-2012 05:18 PM
Upgrading from '03 Harley Davidson, just ordered '11 SCREW iceman302 New Member Check-In 16 11-26-2010 02:37 AM
