Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Upgrading stock OEM trans cooler
This is a discussion on Upgrading stock OEM trans cooler within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Looks like the F250/350/550 Super Duty uses the same bracket. F250 SuperDuty trans cooler: Part # 9C3Z-7A095-A Those trucks have ...
Like Tree100Likes
Old 08-28-2012, 11:05 AM   #11 (permalink)
Those trucks have a double pass oil cooler with inlet and outlet on same side of the cooler. The F150 is a single pass cooler half as big with inlet and outlet on opposite sides.
I have a buddy in the parts dept of local Ford dealer that looked it up, he has both in stock, so I am going to go by sometime this week and we can pull them out of the box and compare them.
Some simple custom hose work on the inlet hose side and I think the F250 SuperDuty cooler should work, for about $250
rbarn is offline   Reply With Quote
Old 08-28-2012, 12:30 PM   #12 (permalink)
Boss Hoss's Avatar
Might think about a larger by 2qt alum finned pan--use better oil such as Amsoil and see how that works! That is what I did and it works very nicely. Also, you are aware that there is a thermostat that controls the tranny fluid as well so it will never stay at 160 let's say.
"Down Before They Hear The Sound"
2015 AMP Built 855hp Z06 C7
2016 2500 Dodge Limited 4in BDS, 36 in Ridge Runner's etc
2016 Macan Turbo
Boss Hoss is offline   Reply With Quote
Old 08-28-2012, 05:30 PM   #13 (permalink)
Donk74's Avatar
Have not tried this yet but have done some research cause I had the same idea.
B&M makes a Super cooler, part number 70264, that is 11" x 6" x 1-1/2". They do make larger coolers that would still fit in the stock location but this is the biggest trans specific cooler. B&M trans coolers have a built on bypass for cold fluid that their larger general use coolers do not.
Will require some custom lines but it should be pretty straight forward install.
Got to LOVE anything fast enough to do something stupid in
Donk74 is offline   Reply With Quote
Old 08-29-2012, 12:28 AM   #14 (permalink)
Donk74's Avatar
Forgot to mention my idea with the B&M 70264 cooler would require 2 coolers. Tied together to make one long 23" long cooler. Its cobbled but should work???
The other option I found is a Tru Cool heavy duty cooler part number 4739. It has a 45,000 BTU ratting and is 8-1/2" x 22" x 1-1/4". Problem with this option is the factory mount only has about 6" maybe 7" of clearance so the mount would need to be moved down or modified to fit this cooler.
I just can't decide if its worth any of this screwing around or not.
Old 08-29-2012, 01:09 AM   #15 (permalink)
cups's Avatar
My thought was a second stock cooler plumbed into that bracket.
cups is offline   Reply With Quote
Old 08-29-2012, 10:44 AM   #16 (permalink)
KaiserM715's Avatar
Kaiser Söze
Originally Posted by rbarn View Post
The plastic bracket holding it in place is designed to take a cooler twice as big. I would think this would improve the stock trans. cooling system without having to drop over a grand on a remote mount cooler, for us guys that dont go out on 8hr desert run sessions, but still want some added cooling.
I am really liking where this is going...
'10 Raptor - My build
'08 G8 GT
- sold
'04 MazdaSpeed Miata
'67 Jeep Kaiser M715 - sold
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Old 08-29-2012, 03:02 PM   #17 (permalink)
Ran into a dead end
We sat down and looked through every transmission cooler in the Ford parts system. F250's, E250's and Expeditions across multiple year models.
Nothing matched up. The F250 cooler is much bigger.
Going to start trying to source cooler cores from 3rd party distributors and see if I can find an exact match based on dimensions.
Stand by I haven't given up on this quite yet.
Old 08-29-2012, 05:56 PM   #18 (permalink)
I have no real experience with this sort of thing but what about additional fans on the stock cooler for a push/pull effect. I'd imagine it would help a lot while adding little cost.
Spider-One is offline   Reply With Quote
Old 08-29-2012, 11:12 PM   #19 (permalink)
Yukon Joe's Avatar
Ran into a dead end
My father owns a radiator shop, I'm sure he could order / built something. I'll look into that too.
Thanks for brining this up, I was thinking the same thing.
Joe
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 08-29-2012, 11:44 PM   #20 (permalink)
cups's Avatar
What about adding, in series or parallel, a second stock cooler? The bracket appears to be set up for it.
FAMARO and willis68 like this.
Ford Raptor Console-to-Cooler Conversion raptorort Ford Raptor Interior Modifications Forum [GEN 1] 18 10-30-2012 05:05 PM
Trans fluid? STUTIDE Ford Raptor Problems and Questions Forum 2 07-23-2012 07:18 PM
Mystery of the Disappearing Cooler E63 Ford Raptor Photos & Videos 0 07-05-2012 11:59 AM
Anyone else have this trans issue? MikeD Ford Raptor Problems and Questions Forum 10 05-17-2012 06:18 PM
Upgrading from '03 Harley Davidson, just ordered '11 SCREW iceman302 New Member Check-In 16 11-26-2010 03:37 AM
