Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Upfittert switches ant the Ford racing light bar with KC lights
This is a discussion on Upfittert switches ant the Ford racing light bar with KC lights within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
I am having a problem. The #1 and #2 upfitter switches are wired up to the KC lights and bar ...
Old 12-03-2010, 06:20 PM   #1 (permalink)
Junior Member
Default Upfittert switches ant the Ford racing light bar with KC lights
I am having a problem. The #1 and #2 upfitter switches are wired up to the KC lights and bar from Ford Racing and worked as they were ment to for about 2 weeks. #1 switch 2 driving lights, #2 swithc to 2 longe range lights and all worked. Now both sets will not come on. I checked the fuse in the 37 position in side the kick panel and it looks OK. I am at a loss. The only other common item shared by the 2 systems is the 4 ground wires are connected at the same point with a bolt to the frame. I have checked every thing amd all connections are tight and no broken wires. I looked at one of the fuses under the hood and as far as I can tell it is OK as well. I swaped around a relay and replaced the 30 amp fuses but still nothing. I dont see 2 seperate systems going down at the same time. Can any one help or should I take to Ford?
baja100 is offline   Reply With Quote
Old 12-03-2010, 06:29 PM   #2 (permalink)
BOJANGLES's Avatar
Administrator
This sounds like a job for Ironman.....
I Get Dirty at FordRaptorForum.com
2010 6.2L | Custom Gold Zinc-Plated Fox 3.0 Shocks & 2.5 Bumpstops | white RPG Stage 4+ | white RPG Raceline 1.5" UCAs | Custom ADD Stealth Front Bumper | Rigid Industries LEDs (White 40" & Amber 40") | VisionX 4502 Spot HIDs on Outlaw Hood Mounts | Deaver +2" Rear Leaf Springs | 17" Method Double Standards | 37" BFG KM2s | Matte Black 3M Vinyl | white Baja Coyote Chase Rack | 20% 3M Tint Everywhere + Eyebrow | RPG Tie Rods Anodized In Gold | WeatherTech Liners & Shades | RPG Power Steering Reservoir Anodized In Gold | CravenSpeed Stubby | ADD ABS Sensor Guards | White & Black Emblems | Magnaflow Race Muffler Dumped To Hidden Black RBP Tip | White PCP Spider Rock Guard on Rear Diff. | Swaybar Delete | Glassworks Unlimited Front Fenders | ColorMatched Rear Flares | Oxford White Sideview Reflectors | Escort 5900ci PassPort with GPS, Laser Shifters, & Hidden Install | Viper 5902 w/ Remote Start, Tilt Sensors, Killswitch, & LCD Remote | Custom Black TX Plates | Raptor Retrofit Headlights (Blacked-Out w/ White Shrouds & Amber Evil Eyes) | Recon Smoked Taillights w/ SuperBright LED's Reverse Bulbs | Crow Enterprizes Harness Pads | Black Line X Premium on Bed, Wheelwells, & Tailgate Emblem Bezel | VIAIR 450P Air Compressor w/ ADD Mount Behind Grille | aFe Stage II CAI | 5star 91 Octane Performance Tune | SDHQ Braided Steel Brakelines
BOJANGLES is offline   Reply With Quote
Old 12-03-2010, 07:42 PM   #3 (permalink)
IRONMAN's Avatar
Super Moderator
How about the fuses in the engine compartment?
There is a black box right up front fuse 18 (Aux 1) and 19 (Aux2)
Also relays 7 (Aux 1) and 10 (Aux 2)..
Did you check those?
I don't know about fuse # 37 inside, because your switches are hooked up to the ones in the engine compartment..Check those and let me know..
IRONMAN is offline   Reply With Quote
Old 12-04-2010, 12:34 PM   #4 (permalink)
Junior Member
It works!!!
I checked all of the fuses again last night and all were good. The #37 fuse in the right hand kick panel is the switch control fuse. It was good. I did start from the begining and took the ground wires off to clean the contact point with no improvement. then I movet the ground from the frame to the front bumper plate screw hole!!!!!!! it worked. Still can't understand how a ground works for a while then quits. o well maby this will help others having a similar problem.
Old 12-04-2010, 04:12 PM   #5 (permalink)
IRONMAN's Avatar
Super Moderator
Originally Posted by baja100 View Post
It works!!!
If a ground is not tight enough and loose it will allow like a film to coat the wires or oxidize. Air, water, dirt whatever, try to coat them with a preventer which can be found at a local hardware/ automotive store. If you tighten it enough it will last longer but eventually it'll happen again.
Good to hear all is fixed.
Old 12-04-2010, 04:33 PM   #6 (permalink)
Junior Member
Thanks for the help, I will try that preventer.
Tags
fuses, lights, upfitter
Ford Light Bar and KC Lights FlounderStalker Ford Raptor Lighting Modifications Forum [GEN 1] 6 10-13-2011 11:29 PM
F150 Eco-Boost racing Chevy Z71 IRONMAN Ford Raptor Photos & Videos 3 10-15-2010 03:37 PM
Ford Raptor Third Brake Light S S M BIRDMAN Ford Raptor Problems and Questions Forum 2 09-18-2010 02:09 AM
