Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
unknown front end noise vibration 4wd?????
This is a discussion on unknown front end noise vibration 4wd????? within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
So my truck was making a small noise that almost sounded like my stability control was being activated on my ...
Old 02-14-2015, 11:55 AM   #1 (permalink)
Junior Member
Default unknown front end noise vibration 4wd?????
So my truck was making a small noise that almost sounded like my stability control was being activated on my left front wheel. I could feel the small vibration on my feet and the steering wheel. Didnt sound to me like what a bad wheel bearing would sound like And it pulled a little to the left. Its hard to describe a sound over the inter web. But if these lines were a noise it would sound like this.. (.) Small break. The ( ) is a big break in sound.
_____._____._____. _____._____._____.
**I should note that this noise started after i put it back to stock perch from top perch.**
after i heard the noise i notice that my tire ripped the vacuum line in half that goes to my 4wd hub.
I have extended warranty and the shop replaced my wheel bearing/hub/4wd actuator. its been about a week and its making the same noise it did before.
I have no idea what it could be and the shop is having a hard time trying to diagnose the noise. Has anyone here had a similar issue that found out what it was?
Thanks guys!
-Mike
BRAAPTR is offline   Reply With Quote
Old 02-14-2015, 12:12 PM   #2 (permalink)
Yukon Joe's Avatar
Is the vacuum valve or actuator bad?
Click here to help:
http://www.fordraptorforum.com/f202/random-military-member-giveaway-40882-post831699/
Yukon Joe
Great Lakes Raptor Excursions
www.runraptorrun.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 02-14-2015, 12:33 PM   #3 (permalink)
Junior Member
They replaced the actuator. Not sure about a valve? is that the solenoid Up on the firewall?
Old 02-14-2015, 12:51 PM   #4 (permalink)
Yukon Joe's Avatar
Yup
Click here to help:
http://www.fordraptorforum.com/showthread.php?p=831699
Yukon Joe
I love Raptorwifey
Old 02-14-2015, 01:13 PM   #5 (permalink)
Junior Member
I'll have to look into how to test it. Would that be something that would cause this
noise?
Old 02-14-2015, 01:47 PM   #6 (permalink)
Yukon Joe's Avatar
If it's not working properly it could be letting the IWE to partially engage when you don't want it to.
Click here to help:
Yukon Joe
I love Raptorwifey
Old 02-16-2015, 02:21 PM   #7 (permalink)
FordService's Avatar
Ford Professional
Originally Posted by BRAAPTR View Post
...its been about a week and its making the same noise it did before...
Hi Mike,
Let's see what I can do to help. What's your truck's model year/mileage? I'll start researching some options.
Crystal
FORD SERVICE
p: 800.392.FORD
t: @FordService @FordTrucks @Ford
f: facebook.com/FordTrucks facebook.com/Ford
FordService is offline   Reply With Quote
Vibration drivers side front sisca Ford Raptor Problems and Questions Forum 6 01-24-2016 07:19 AM
New Front End Noise Fred Ford Raptor Problems and Questions Forum 17 05-28-2013 03:31 PM
Front end noise mrpork Ford Raptor Problems and Questions Forum 74 01-06-2013 10:11 PM
Unknown Bed cage/Rack Netix Ford Raptor Exterior Modifications Forum [GEN 1] 12 06-06-2012 05:12 PM
Noise from front when stopping FireLT Ford Raptor Problems and Questions Forum 10 03-01-2012 08:29 AM
