I know this is not your favorite subject FSM hahaha, and that it has been spoken about a lot but my question is....I recently brought my truck into the dealership to have the latest TSB 10-12-4 5.4L 3V and 6R80 transmission done, or at least I believe they did it not sure. I came to a stop yesterday and I felt that little bump again like someone bumped me from behind.It's only been a little over a week since it's been completed. Should I wait longer before thinking about anything? Was wondering maybe they just reset the adaptive learning tables or whatever its called, again and that's it.
Is there any way of checking to see if the lastest update was in fact completed?
First of all IRONMAN, thank you for the question and actually this is one of my favorite subjects.
Let's start by addressing the TSB that you mentioned which is a reprogram of the PCM/TCM to address a harsh downshift above 40 mph......only. It does not address a 2-1 downshift bump at low speed.
There is a SSM that covers the 2-1 coasting downshift "bump" which simply states for vehicles that experience this, it may be significantly improved by performing the adaptive drive cycle. My suspicion is that the Dealer performed the TSB and nothing else. BIRD, in your case, the Dealer may have performed the TSB, cleared the adaptive trans shift tables, and then performed an adaptive drive cylce to "cover all the bases", which knowing what I know and driving one myself, would perform for any of our customers that expressed concern with the way the Raptor shifts.
I will also state that the adaptive learning never really stops, hence the term "adaptive". I recenty traveled to Denver where I had to pull a 6% grade pulling a camp trailer. After reaching Denver and returning to in town driving, the shifts were a tad firmer and the 2-1 "bump" was present when coming to a stop. Likely due to the heightened line pressures that the trans had to use during the shifting usage while pulling the pass. Few days later, the "feel" of the trans is "back to normal".
Hope that answers your question.
FSM
P.S. One thing I might add that hopefully will help. The 6R80 transmission has no bands or OWC's (one way clutches) so timing is very critical when one clutch is released and another applied. This is why Ford states that some of the shift "feel" that everyone is concerned about is "inherenent to the synchronous nature of the 2-1 shift" to quote FoMoCo. As hard as some of it's shift nature is to get used to, it has certainly been a stud of a transmission in that I have heard of hardly any hard failures.
