Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Mechanical Problems and Questions Forum
Sponsored Ads
Tsb 11-7-20 ?
This is a discussion on Tsb 11-7-20 ? within the Ford Raptor Mechanical Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Register to remove these ads. It's free! See next post...
Old 10-07-2011, 10:46 AM   #31 (permalink)
gordhunt's Avatar
See next post
gordhunt is offline   Reply With Quote
Old 10-07-2011, 10:56 AM   #32 (permalink)
swoop1156's Avatar
Originally Posted by gordhunt View Post
I think its the memory feature in the productivity screen if you set it to memory on it brings up stuff you had on the screen everytime you start it. So if you have the gear indicator turned on it will leave it on. Try it out I dont think it has anything to do with any updates.
Negative. The memory feature is used for when you switch from Truck Apps, Mileage, Apps or whatever they're called, when you hit down or up, it doesn't kick you back out to the selection screen, it just goes right to it.
2011 Ingot Silver SuperCrew
353 RWHP / 369 RWTQ -- Tuned by Livernois Motorsports
| Nav | Sunroof | Luxury | Plus | BedRug | BakFlip F1 | 15% Tint | WeatherTech Liners | Airaid Intake | Corsa Cat-Back | RIGID 40" LED |
http://www.fordraptorforum.com/members/swoop1156/]
swoop1156 is offline   Reply With Quote
Old 10-07-2011, 02:00 PM   #33 (permalink)
gordhunt's Avatar
You are correct the latest pcm flash is what fixes it. I had my truck in at the dealer yesterday and didnt realize they had flashed it thats why mine works now
Old 10-23-2011, 03:31 PM   #34 (permalink)
I wish they'd give us an update to show oil and water temp in the productivity "gauge" section.
And to someone that posted before, my truck is build mid-April '11 and downshifts 3-1 as well. Smooth, no issues in doing it. It will only downshift to 2nd using tow/haul or if I'm in 3rd and decide to squeeze on it a little bit, it will downshift to 2nd. I didn't take it as a flaw really.
mblgjr is offline   Reply With Quote
Old 11-12-2011, 08:14 PM   #35 (permalink)
just had this tsb performed today and now my gear indicator lights function the same as everyone else; i.e., they stay on in Drive mode
WannaRaptor62 is offline   Reply With Quote
Old 11-12-2011, 08:55 PM   #36 (permalink)
Ruger's Avatar
What does this mean:
6.2L Engine:
Improved Calibration to prevent False P0711 DTC
Improved Calibration to prevent False P2610 DTC
Ruger is offline   Reply With Quote
Old 11-12-2011, 09:42 PM   #37 (permalink)
Droid's Avatar
kglesq's Brother
Thanks everyone, really need to get mine in for this (and the driveshaft!) I literally turn those things on as a procedure every time I put it in drive right now.
6.2L Engine:
The update prevents the ECM (engine control module) from setting incorrect diagnostic trouble codes (DTCs). Normally a DTC will show up as a "check engine" light.
P0711 = Transmission Fluid Temperature Sensor Circuit Range/Performance
No clue what P2610 is. Got P0711 from OBD-II Check Engine Light Trouble Codes
2011 Black Supercrew
Droid is offline   Reply With Quote
Old 01-31-2012, 08:24 PM   #38 (permalink)
Droid's Avatar
kglesq's Brother
Paying $120 to get this done. Fucking pissed. Will be contacting Ford customer service, dealer can't do it under warranty without specific codes in TSB having been thrown/recorded. Dealer (Theodore Robins) appears innocent given that they can't bill Ford.
Fully Driven Auto Network
