Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Transmission issues
This is a discussion on Transmission issues within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
I have a 2011 S crew 6.2 with 82,000 miles. Recently had trans flushed at dealer because I was experiencing ...
Like Tree6Likes
Old 01-27-2016, 10:39 AM   #1 (permalink)
Jfreeze's Avatar
Junior Member
Default Transmission issues
I have a 2011 S crew 6.2 with 82,000 miles. Recently had trans flushed at dealer because I was experiencing "chirping sound when shifting" Tech advised that the fluid breaks down etc. soon thereafter I started getting a Dead pedal when downshifting after slowing down, the trans try's to go from say 4th to 1st & figures out speed is too fast for 1st gear & gives me dead pedal which quickly goes away and resumes as normal once it figures out what gear to choose. I also am experiencing hard downshifting from high gear to say 3 or 4th, & a delayed or exaggerated 3-4 up shift ( like an old C6 transmission)Ford diagnosed it as possible TB problem, which I replaced with a BBK & actually like a lot but did not fix problems. Any input or help is appreciated
Jfreeze is offline   Reply With Quote
Old 01-27-2016, 10:53 AM   #2 (permalink)
t_j's Avatar
t_j
First flush after 82k miles? These things need to be flush either regularly, or never, I've heard plenty of horror stories of trans failure shortly after first flush at a high milage. The other thing it could be is the valve body in the trans.
t_j is offline   Reply With Quote
Old 01-27-2016, 11:19 AM   #3 (permalink)
Mariner's Avatar
When should we do our first tranny flush?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Mariner is offline   Reply With Quote
Old 01-27-2016, 11:35 AM   #4 (permalink)
t_j's Avatar
t_j
I've heard 30k intervals is best, ford recommends 60k for the first flush.
Mariner likes this.
Old 01-27-2016, 11:54 AM   #5 (permalink)
Jfreeze's Avatar
Junior Member
Ok the flush was actually done at 75,000 miles, which is over recommended interval by 15,000 & water under the bridge. Besides stating the obvious has anyone out there experienced these symptoms before? I am suspecting shift solenoids, molded lead into the transmission, or ECM/TCM. I am not covered by any warranties so don't want to just start throwing money at it.
Old 01-27-2016, 12:07 PM   #6 (permalink)
CoronaRaptor's Avatar
As T_J mentioned I think it is the valve body, do some more research, but that was a common problem with which you are describing. I haven't done my tranny yet @90,000 miles currently.
CoronaRaptor is offline   Reply With Quote
Old 01-28-2016, 10:24 AM   #7 (permalink)
FordService's Avatar
Ford Professional
Hi Jfreeze,
It might be wise to return to the dealership so they can take a look at these new symptoms. If that's something you decide to do, let me know; I'll be happy to step in and do what I can to assist.
Crystal
FORD SERVICE
p: 800.392.FORD
t: @FordService @FordTrucks @Ford
f: facebook.com/FordTrucks facebook.com/Ford
FordService is offline   Reply With Quote
Old 01-28-2016, 12:10 PM   #8 (permalink)
Jfreeze's Avatar
Junior Member
Thanks Crystal
All of these symptoms were originally recorded when the diagnosis came back as the Throttle body. I actually had the shop foreman ride with me. The dealership that I took it to is where I bought the truck new for sticker price. I can't say that I was ever thrilled with the way it shifted since new, but now it is definitely something that needs to be fixed. I'm not sure if it should go back to them or what ? Any help or suggestions are greatly appreciated
Jason
Old 01-28-2016, 01:45 PM   #9 (permalink)
Ford Professional
Thanks Crystal
Jason
Hi Jason,
I'd recommend returning to the initial dealership that first performed the work, however, you are welcome to visit any Ford Dealership for service. If you'd like, I can arrange for your regional customer service manager (CSM) to give you a call. To make that happen, PM me your full name, best daytime phone number, VIN, current mileage, and preferred servicing dealership.
Crystal
depgary25 likes this.
FORD SERVICE
p: 800.392.FORD
Old 01-28-2016, 05:01 PM   #10 (permalink)
I had a strange sound under hard load and downshift; they added "friction additive" per a TSB and it was solved.
aR4CE is offline   Reply With Quote
Tags
dead pedal, hard shifts, problems, transmission
TSB 11-3-25 - Transmission bulkhead connector sleeve leaking transmission fluid pirate air Ford Raptor Recalls | TSB's | SSM's 8 04-17-2016 02:54 PM
2010 Transmission Issues *jrwiii* Ford Raptor Problems and Questions Forum 0 06-11-2013 10:32 AM
4L transmission issues brusso99 2012 Ford SVT Raptor Forum (Reply Only) 21 09-06-2012 07:52 PM
Transmission issues Hocker52 Ford Raptor Problems and Questions Forum 21 04-11-2012 05:22 PM
Raptor transmission issues Dizzytablet Ford Raptor Problems and Questions Forum 48 06-15-2011 03:07 PM
