Transfer case crack and failure
Milowilli
Anybody seen this type of failure? 2010 5.4L Raptor. It's a complete crack all around the case behind the bolt up flange. The case was replaced.
Night_Stalker
Yukon, ok
I also have a busted one same place. Dealer ship saying my fault because rear shocks have been fully compressed.
It is also has broken piece inside transmission.
I was in the shop 3-4 times for vibration and told them to look at rear output it has play. They said it was okay.
Manager said 1663 to replace.
Night_Stalker
Yukon, ok
Yes all stock. No performance mods.
That is what I said, told him it would have bump stops first.
I m trying to get a ford rep. To help
Night_Stalker
Yukon, ok
No other damage.
Yukon Joe
Trafford, PA
I had a steering gear housing crack when my truck was brand new. About 10,000 miles on it. I unfortunately couldn't get it covered as well. Said it was abuse. I also has an aftermarket tie rod, so I couldn't argue. But sounds like you should have a chance.
Yukon Joe
www.RUNRAPTORRUN.com
Night_Stalker
Yukon, ok
It makes me mad because I told them there is a problem I have the work orders. 3 times I was in there complaing about transfercase problems. They said eveything is okay.
Just starting to get bad taste about ford. Truck has been in shop more then any truck I have owned.
3000 miles ago had new engine put in. Now it burns a qrt of oil in 2500 miles. Still not fixed, also anti freeze is low.
Along with a passanger door problem.
Just saying buy a new truck and get the shaft.
Like your steering gear housing how can that part be abused. You and netix both broke it, I work in the oil patch and we drive company trucks like we stole them, I drive it harder then the raptor and when it rains it gets muddy. Never have had any problem, maybe ford needs to look into problems a little better.
Every time somebody says my master servise tech. Said. I just roll my eyes. Most the time the guy is some kid out of school.
