Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
transfer case ?!?!
This is a discussion on transfer case ?!?! within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Well here is the problem. Driving the truck in 2wd everything works as it should. When you put it in ...
Old 08-15-2016, 04:56 PM   #1 (permalink)
Junior Member
Default transfer case ?!?!
Driving the truck in 2wd everything works as it should. When you put it in 4wd hi or 4wd low it makes a LOUD popping/metal to metal noise when turning hard or very slightly. Im talking LOUD popping noise. When I disengage the 4wd the truck still wants to act like it's in 4wd as well. What is goin on here !?! Uhhhh
Thanks fellas
2011_Ford_Raptor is offline   Reply With Quote
Old 08-15-2016, 04:59 PM   #2 (permalink)
Might be iwe's or cv's
98infinity is offline   Reply With Quote
Old 08-15-2016, 05:33 PM   #3 (permalink)
Junior Member
I thought cv's as well but was told by a mechanic it definitely wasn't my cv's. Iv heard of the iwe's but I don't know what that is. BTW thanks for your reply!
Old 08-15-2016, 07:37 PM   #4 (permalink)
raulsterXDozer's Avatar
Definitely sounds like Ford's shitty 4x4 system aka IWE's. That noise you hear is the iwe slipping, re-engaging and slipping again etc.
Everything you wanted to know about IWE and then some...
raulsterXDozer is offline   Reply With Quote
Old 08-15-2016, 08:23 PM   #5 (permalink)
Sage's Avatar
A little more information is needed:
High or low range or no difference?
Speed when shifting?
Sitting still?
Under power, hard power, no power, light power when shifting?
Sage is online now   Reply With Quote
Old 08-15-2016, 09:49 PM   #6 (permalink)
2014RubyRed's Avatar
If it's the IWE's and has been happening for a while, you most likely have a vacuum leak. Get that fixed first (may be a line or the vacuum pump or both). Once that is done, do yourself a favor and change both hubs. Historically, if the IWE's have been popping for a while then the hubs are junk too. Putting new IWE's in with used-up hubs will just recreate the issue soon.
Good luck!!!
2014RubyRed is offline   Reply With Quote
Old 08-16-2016, 07:25 AM   #7 (permalink)
EricM's Avatar
Good luck!!!
These trucks have vacuum pumps?
2013 Tux Black SuperCrew.
Nobody gives a crap where your post was sent from...
EricM is offline   Reply With Quote
Tags
transfer case ?
Blown transfer case??? johndjmix Ford Raptor Problems and Questions Forum 19 10-22-2015 03:51 AM
SVT Transfer case vs Crew cab Acerni Ford SVT Raptor General Discussions [GEN 1] 0 03-30-2015 05:03 AM
Transfer case maybe? Little man Ford Raptor Problems and Questions Forum 14 03-04-2015 11:18 AM
Transfer case being replaced... Steele16 Ford Raptor Problems and Questions Forum 12 11-14-2014 01:17 PM
Transfer Case Fluid Question Vash Ford Raptor Problems and Questions Forum 23 06-20-2014 03:50 PM
