Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Trans problem
This is a discussion on Trans problem within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Hey everyone, I just bought my new 14 SCREW back in Feb and just recently I have noticed that the ...
Old 05-09-2014, 03:45 PM   #1 (permalink)
Junior Member
Default Trans problem
Hey everyone,
I just bought my new 14 SCREW back in Feb and just recently I have noticed that the trans fluid has been leaking onto my drive way. I took it into the dealership and they replaced a few parts that they said were faulty (can't remember exactly which parts)
a day after getting it back I again noticed trans fluid leaking onto the driveway,
has anyone else had this problem or no what it could be since the guys at the dealership clearly don't or don't know how to fix it/ half ass job.
buresh88 is offline   Reply With Quote
Old 05-09-2014, 06:02 PM   #2 (permalink)
Icecobra's Avatar
Somewhere on here is Crystal let her get involved she is not with the Government she really is here to help...
Lord, make my hand fast and accurate.
Grant me victory over my foes and those who wish to do harm to me and mine.Let not my last thought be 'If I only had my gun."And Lord, if today is truly the day you call me home, let me die in an empty pile of brass. My biggest fear running out of ammo
Icecobra is offline   Reply With Quote
Old 05-09-2014, 06:20 PM   #3 (permalink)
Fred's Avatar
Knowing the dealers, they just did not clean their mess up and the new fluid is just excess...did you climb under the truck and look?
Either way take the truck back....
Fred is offline   Reply With Quote
Old 05-09-2014, 06:57 PM   #4 (permalink)
Junior Member
yeah i went under after i got it back and cleaned everything and about 2 days later noticed it pooling up again under and then the drops on the driveway. taking it back in the morning
Old 05-09-2014, 07:01 PM   #5 (permalink)
Fred's Avatar
Good luck and keep posted...
Old 05-09-2014, 11:46 PM   #6 (permalink)
Yukon Joe's Avatar
Cracked bell housing
Yukon Joe
www.RUNRAPTORRUN.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 05-10-2014, 02:41 PM   #7 (permalink)
BIGt0007's Avatar
there is a tsb out there for this.. its like some kinda pass through wiring. that might not have been done properly.
TSB 11-3-25 - Transmission bulkhead connector sleeve leaking transmission fluid
I had this prob, tech at dealer did a great job
BIGt0007 is offline   Reply With Quote
Old 05-10-2014, 03:40 PM   #8 (permalink)
Junior Member
I had the same leak on my 09 f150 4x4 the tans harness plug that comes out of the case has a Oring or some sort of rubber seal that fails if I rember correctly they rpl the harness that's inside the trans. When I took it in for the repair they had to order the parts and I was told it is a common failure.
Mike
dew34 is offline   Reply With Quote
Old 05-12-2014, 11:52 AM   #9 (permalink)
6gun's Avatar
I also had a similar leaking problem. The issue was the front transmission pump housing was leaking. They had to drop the tranny and R&R the pump. Was told by dealer that Ford got a batch of pumps that had bad housings and the leak showed up on the bottom of the bell housing.
6gun is offline   Reply With Quote
Old 05-12-2014, 12:12 PM   #10 (permalink)
FordService's Avatar
Ford Professional
Hey everyone,
a day after getting it back I again noticed trans fluid leaking onto the driveway...
Time to get me involved, buresh88. PM me your full name, best daytime phone number, VIN, mileage, and servicing dealership; I'll get this into the hands of your regional customer service manager.
Crystal
FORD SERVICE
p: 800.392.FORD
t: @FordService @FordTrucks @Ford
f: facebook.com/FordTrucks facebook.com/Ford
FordService is offline   Reply With Quote
Tags
2014 raptor, leak, problem, transmission
Trans. Temp raptor4122 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 6 11-26-2013 11:08 PM
Trans issues? Mike TexaSS Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 9 01-30-2013 03:35 PM
Trans Service? keatonskidmore Ford Raptor Maintenance Forum 15 09-21-2012 03:52 PM
Trans fluid? STUTIDE Ford Raptor Problems and Questions Forum 2 07-23-2012 06:18 PM
6.2 and trans shifting... SLB8SNK Ford SVT Raptor General Discussions [GEN 1] 12 07-16-2010 10:51 AM
