Just so I understand this can someone intelligently tell me if I am correct here?
I spoke with Bojangles this weekend because I noticed the protruding nub on the front side of the lower control arm(which I am calling the steering stop) looks pretty marred up on my truck.
Upon further investigation I can clearly see that a part on the lower hub assembly contacts that nub at full inner turn of either side.
I also noticed immediately after doing the top perch mod that I get the sensation of the front end lifting at full turn. I have to guess that the angle of the control arm is causing the steering stop to hit higher and the lower control arm gets pushed down. I am also assuming this is the reason for the excessive wear on the part.
Now can someone explain this intelligently?
